.NET
Block Name - Please help
2 REPLIES 2
Natalie-C
168 Views, 2 Replies
OK, this is the code I have......
For Each id In btr
Dim ent As Entity = CType(trans.GetObject(id, OpenMode.ForRead, False), Entity)
If TypeOf ent Is BlockReference Then
Dim br As BlockReference = CType(ent, BlockReference)
If br.Layer() = "WantedLayer" Then
'DO STUFF
End If
End If
I know I can get the layer id by br.LayerID and I can get the block id by br.BlockID. What I really need is the Block Name. Can anyone point me in the right direction??
Thanks in advance!
2 REPLIES 2
Mikko
in reply to: Natalie-C
Something similar to this:
Dim blkRef As BlockReference
blkRef = ent
Dim BRId As ObjectId = blkRef.BlockTableRecord
Dim btr As BlockTableRecord
btr = CType(trans.GetObject(BRId, OpenMode.ForRead), BlockTableRecord)
MsgBox("Your Block Name Is " + btr.Name() + vbCrLf)
End If
Natalie-C
THANK YOU SOOO much! That's exactly what I needed.
”Boost
