.NET
Block Jig with attributes
0 REPLIES 0
Message 1 of 1
832 Views, 0 Replies
Hi, I am trying to create a jig for inserting blocks containing attributes and defining Insertion Point, X Scale, Y Scale & Rotation at jig time.
This is fine, I am using a entity jig and have used information from Kean's article to include the attributes- http://through-the-interface.typepad.com/through_the_interface/2009/03/jigging-an-autocad-block-with...
The only problem I am facing is that the attributes are not scaling as part of the jig and require an "ATTSYNC" command after the jig has completed for them to display correctly.
Can anybody help me with this or point me to some more reading that could help?
Code attached
Many thanks
0 REPLIES 0
”Boost
