.NET
.NET
Hallex
Message 11 of 23 (283 Views)
Re: Block-Functions (Select, Explode, etc.)
04-17-2012 10:07 AM in reply to: klahie
Sorry, try converted on C# instead
        public static void ApplyAttributes(Database db, Transaction tr, BlockReference bref)
            BlockTableRecord btrec = tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead) as BlockTableRecord;
            if (btrec.HasAttributeDefinitions)
                Autodesk.AutoCAD.DatabaseServices.AttributeCollection atcoll = bref.AttributeCollection;
                foreach (ObjectId subid in btrec)
                    Entity ent = (Entity)subid.GetObject(OpenMode.ForRead);
                    AttributeDefinition attDef = ent as AttributeDefinition;
                    if (attDef != null)
                        AttributeReference attRef = new AttributeReference();
                        attRef.SetDatabaseDefaults();
                        attRef.SetAttributeFromBlock(attDef, bref.BlockTransform);
                        attRef.Position = attDef.Position.TransformBy(bref.BlockTransform);
                        attRef.Tag = attDef.Tag;
                        attRef.TextString = attDef.TextString;
                        attRef.AdjustAlignment(db);
                        atcoll.AppendAttribute(attRef);
                        tr.AddNewlyCreatedDBObject(attRef, true);
        [CommandMethod("insBlock", CommandFlags.Modal | CommandFlags.UsePickSet)]
        public void TestInsert()
            string blkname = "VT_VZ_VZ52_10a_ATT";
            //'<-- as per as on your drawing
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            try
                using (DocumentLock docloc = doc.LockDocument())
                    using (Transaction tr = db.TransactionManager.StartTransaction())
                        BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                        if (!bt.Has(blkname))
                            ed.WriteMessage("\nBlock does not exists");
                            return;
                        PromptPointOptions pto = new PromptPointOptions("\nPick a block insertion point: ");
                        PromptPointResult ptres = ed.GetPoint(pto);
                        Point3d ipt = default(Point3d);
                        if (ptres.Status != PromptStatus.Cancel)
                            ipt = ptres.Value;
                        BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite, false);
                        BlockTableRecord blk = (BlockTableRecord)tr.GetObject(bt[blkname], OpenMode.ForRead, false);
                        BlockReference bref = new BlockReference(ipt, blk.ObjectId);
                        bref.BlockUnit = UnitsValue.Millimeters;
                        bref.Rotation = 0;
                        bref.ScaleFactors = new Scale3d(1000.0);
                        btr.AppendEntity(bref);
                        tr.AddNewlyCreatedDBObject(bref, true);
                        ApplyAttributes(db, tr, bref);
                        ed.Regen();
                        tr.Commit();
            catch (System.Exception ex)
                ed.WriteMessage(ex.Message);
~'J'~
chiefbraincloud
Message 12 of 23 (279 Views)
04-17-2012 10:15 AM in reply to: Hallex
I forgot all about "\n".
Shame on me.  My lisp programming skills are getting too rusty.
Hallex
Message 13 of 23 (277 Views)
04-17-2012 10:37 AM in reply to: chiefbraincloud
But you know many other stuffs,
Oleg
Hallex
Message 14 of 23 (275 Views)
04-17-2012 10:40 AM in reply to: klahie
What about Copy-Paste, just a quick code almost not tested
        [CommandMethod("copypaste", CommandFlags.Modal | CommandFlags.UsePickSet)]
        public void CopyPaste()
            Matrix3d ucs = ed.CurrentUserCoordinateSystem;
            try
                    PromptEntityOptions peo = new PromptEntityOptions("\nSelect a block  >>");
                    peo.SetRejectMessage("\nSelect block only >>");
                    peo.AddAllowedClass(typeof(BlockReference), false);
                    PromptEntityResult res;
                    res = ed.GetEntity(peo);
                    if (res.Status != PromptStatus.OK)
                        return;
                    Entity ent = (Entity)tr.GetObject(res.ObjectId, OpenMode.ForRead);
                    if (ent == null) return;
                    ObjectIdCollection ids = new ObjectIdCollection();
                    ids.Add(ent.ObjectId);
                    ObjectId chkId = ent.ObjectId;
                    BlockReference bref = ent as BlockReference;
                    Point3d pt = Point3d.Origin;
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    Point3d ipt=Point3d.Origin;
                        ipt = ptres.Value;
                    using (IdMapping map = new IdMapping())
                        db.DeepCloneObjects(ids, bref.BlockId, map, false);
                        ObjectId clid = map[bref.ObjectId].Value;
                        BlockReference brefclone = (BlockReference)tr.GetObject(clid, OpenMode.ForWrite);
                        brefclone.Position =ipt;
                    tr.Commit();
~'J'~
Active Contributor
klahie
Message 15 of 23 (272 Views)
04-17-2012 10:46 AM in reply to: chiefbraincloud
EDIT: Wow, wow, wow, I was reading the first page and didn't see the second page :smileylol:
That solved the second problem! :smileyhappy:
How should I use chr(13)?
PromptPointOptions pto = new PromptPointOptions(chr(13) + "Pick a block insertion point: ");
 gives the same problem
Greets
Klaus
chiefbraincloud
Message 16 of 23 (267 Views)
04-17-2012 10:53 AM in reply to: klahie
Well, I am surprised the chr function is not automatically in c#, but anyway, Oleg's code reminded me of the appropriate way to send a newline in c# (and lisp)  use "\nPick a block insertion point: "
Active Contributor
klahie
Message 17 of 23 (261 Views)
04-17-2012 11:16 AM in reply to: chiefbraincloud
:smileyvery-happy: That's great!
The block is pasted dreamlike. :smileyhappy:
BUT: When I refresh my blocklist, I havn't got a new entry for the pasted block. That means, in my list is only the old entry.
public void setBlockList()
   BlockList = new List<String>();
   using (tr = db.TransactionManager.StartTransaction())
      foreach (ObjectId objId in bt)
         BlockTableRecord btr = (BlockTableRecord)tr.GetObject(objId, OpenMode.ForRead);
         if (isAttDef(btr))
            BlockList.Add(btr.Name);
 That is my Blocklist-Function.
Do you know why it fails?
Greets
Klaus
Hallex
Message 18 of 23 (254 Views)
04-17-2012 11:55 AM in reply to: klahie
I didn't see nothing wrong with your code
Perhaps you might be want to refresh BlockList first
Something like:
          List<String>  BlockList = new List<String>();
                    if (btr.HasAttributeDefinitions)
                   // if (isAttDef(btr))
            foreach (string bname in BlockList)
                ed.WriteMessage("\n{0}", bname);
~'J'~
Active Contributor
klahie
Message 19 of 23 (250 Views)
04-17-2012 12:13 PM in reply to: Hallex
I call my setBlockList()-Function direkt after the Commit. No Copy-Blockname..... :smileyindifferent:
In the commandline (
) is only one blockname too, the blockname of blk (using the function you posted).
Greets
Klaus
chiefbraincloud
Message 20 of 23 (239 Views)
04-17-2012 03:15 PM in reply to: klahie
I don't think it is failing.
I think you still don't quite understand the difference between a BlockReference and a BlockTableRecord.
You are listing BlockTableRecords in your Block List.  When you copy/paste, you are creating a new BlockReference pointing to the same BlockTableRecord as the original copied BlockReference.  This does not create a new BlockTableRecord.
There can only be one BlockTableRecord with a given name, but there can (and usually will be) many BlockReferences that point to same BlockTableRecord.  That is really the point of Blocks, that you store the definition of the block (BlockTableRecord) once in the BlockTable, and then you create multiple instances of the block (BlockReference) as many times as needed in the Model or Paper spaces.  This saves space in the database and keeps the drawing size smaller, because the BlockReferences just contain a pointer to the BlockTableRecord, instead of containing all of the information for the lines, polylines and whatever other geometry they might contain.
I'm still looking for the old post of mine that explains the difference in greater detail...
