.NET
.NET
Hallex
Message 11 of 13 (116 Views)
Re: Block Created and Inserted Shows Text Entities at Origin Until Regen'd By Us
09-05-2012 02:02 PM in reply to: calvindale
Sorry I can't help with it,
just an idea > try ed.UpdateScreen(); at the end of code
currently I just have a AutoCAD 2010 on my machine installed
~'J'~
Active Contributor
calvindale
Message 12 of 13 (113 Views)
09-05-2012 02:11 PM in reply to: Hallex
Yeah thanks...I have tried that and also with Editor.Regen()'s interspersed before and after.   So far to no avail.
ADN Support Specialist
Balaji_Ram
Message 13 of 13 (82 Views)
09-12-2012 05:42 AM in reply to: calvindale
It is quite hard to say what might be causing it with only the code snippet.
You may try using the DBText.adjustAlignment method.
This is the explanation for this method from the documentation :
"....if the text entity is embedded in another entity, it will never be closed in
which case it won't automatically be adjusted....."
Also if you have side database, then ensure that it is the working database before calling the adjustAlignment method.
Balaji
Developer Technical Services
Autodesk Developer Network
