Show only
Search instead for
This isn't you exactly need but it will be show you
the method to change properties of attributedefinition
(eg attribute prompt)
Same way for new attribute tag
Could you also post the code that calls this function? I'd like to see how the blockreference variable is passed into this function. In particular the mechanism to figure out which blockreference to select.
