.NET
coddy
Message 11 of 14 (229 Views)
Re: Bind Xrefs
04-07-2008 09:59 PM in reply to: bertyboy
BindXrefs function is fine and works great. It doesn't work if I run the scalelist command to reset the scales.
I haven't seen AutoCAD 2009. I'm really waiting to see.
New Member
ismailcetin
Message 12 of 14 (229 Views)
Re: Bind Xrefs
11-12-2009 06:06 AM in reply to: bertyboy
hi bertyboy,
Your Code is very Successful but i don't understand the row
bSave(bDwg)
matus.brlit
Message 13 of 14 (229 Views)
Re: Bind Xrefs
05-13-2010 05:34 AM in reply to: bertyboy
This code was very helpful for me, thank you.
But sometimes, i get an error, when binding the xrefs. The error code is 304, Unknown error. I found an error code description, that says, "304 User is disabled", which gives me no clue.
But despite that error, the xrefs are bound. UNLESS they have nested xrefs, in this case, only the main xref is bound, not the nested ones.
Did anyone else come across this problem?
Valued Mentor
AubelecBE
Message 14 of 14 (165 Views)
Re: Bind Xrefs
01-24-2012 03:43 AM in reply to: bertyboy
hi.
have you try to modifiy your :
CommandMethod("BindAllXrefs")> _
by
CommandMethod("BindAllXrefs",CommandFlags.Session)> _
i have to use this flag.. I need to save and close the current document. but if i try this the BindXref not working....
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
