.NET
Bind Xrefs
13 REPLIES 13
Message 1 of 14
1734 Views, 13 Replies
Bind Xrefs
Hi to all. I have'nt seen a lot on xrefs bind. So I've done an effort on my side and wanted to share this code with you. It's a basic Bind Command. You can send me your comments if you wish!
Don't forget to put the < before the commandmethod!!!
Imports Autodesk.AutoCAD
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
CommandMethod("BindAllXrefs")> _
Public Sub BES()
Dim bTransMan As DatabaseServices.TransactionManager
Dim bTrans As DatabaseServices.Transaction
Dim bDwg As Document
Dim bBT As BlockTable
Dim bBTR As SymbolTableRecord
Dim bBTE As SymbolTableEnumerator
bDwg = Application.DocumentManager.MdiActiveDocument
bTransMan = bDwg.TransactionManager
bTrans = bTransMan.StartTransaction
Try
'Open the database for Read
bBT = bDwg.Database.BlockTableId.GetObject(OpenMode.ForRead)
bBTE = bBT.GetEnumerator
Dim XrefIds As New ObjectIdCollection
While bBTE.MoveNext = True
bBTR = bBTE.Current.GetObject(OpenMode.ForRead)
'Check if block is xref and add if so, add it's ID to the ObjectIdCollection
If bBTR.IsResolved And Not bBTR.Name.Contains("|") Then
XrefIds.Add(bBTR.Id)
End If
End While
'Bind xref of collection
bDwg.Database.BindXrefs(XrefIds, True)
'Important to commit
bTrans.Commit()
Catch ex As Exception
MsgBox(ex.Message, MsgBoxStyle.Critical)
Finally
bTrans.Dispose()
bTransMan.Dispose()
End Try
End Sub
13 REPLIES 13
Message 2 of 14
Hi Again! I just wanted to specifie that this code is for Autocad 2008.
And also Merry Christmas to all !!!
Message 3 of 14
Thanks for the code. But I have a question. What if the xrefs are unresolved? How do I handle the unresolved xrefs, like 'Not Found', 'Unloaded', 'Unreferenced'?
Message 4 of 14
I love good questions!
I'm not an expert on this. But I find out that you could convert the
"SymbolTableRecord" to a "BlockTableRecord" with:
dim BlcTabRec as BlockTableRecord = _ Ctype(YourSymTableRecVariable,BlockTableRecord)
the BlcTabRec have a couple of property you could use.
Like:
IsUnloaded
IsFormExternalReference
IsResolved
But for the:
'Not Found', 'Unreferenced'
I think you could use the "IsResolved" property.
If Not IsResolved(BlcTabRec ) then Msgbox "Problem here!!"
Just for information, there's an automatic Bind command part of the etransmit command in Autocad 2008. That's very cool!
Cad Programmer
Bert
Message 5 of 14
You're great, man!
What is YourSymTableRecVariable? Could you please help on how that would go into code.
Message 6 of 14
And why the _?
Message 7 of 14
Ok...I got it!
Dim BlkTabRec As BlockTableRecord = CType(bBTR, BlockTableRecord)
But unfortunatly it's not working.
Message 8 of 14
Me it's working very fine. So I send you the code updated.
Oh ya! You guessed right for what you wrote!
Imports Autodesk.AutoCAD.EditorInput
Imports Microsoft.Office.Interop
Imports Microsoft.VisualBasic.ApplicationServices
Imports System.IO
< CommandMethod("BindAllXrefs") > _
Public Sub BES()
Dim bBTRr As BlockTableRecord
' Current Document
Try
' Open the database for Read
bBTRr = CType(bBTR, BlockTableRecord)
' Check if block is xref and also resolved and thenadd its ID to the ObjectIdCollection
If bBTRr.IsFromExternalReference And bBTRr.IsResolved Then
End If
End While
' Bind xref of collection
Try
'We bind all xrefs of drawing
MsgBox("Error: " & ex.Message)
End Try
' Important to commit
bTrans.Commit()
bSave(bDwg)
Finally
bTrans.Dispose()
bTransMan.Dispose()
End Try
End Sub
Maybe if it doesn't work, a error message could help you up!
Cad Programmer
Bert
Message 9 of 14
After a long gap!
Thanks for the code. I did some modifications in the code to suit my requirements, and it did work fine. But after I run a certain AutoCAD command, I get an error that says 'eWasOpenForWrite'. Seems like the command is opening the database and forgets to close! Is there any workaround that can be done in our code?
Message 10 of 14
You should be an expert of vb.net by the time! 🙂
I don't know, I haven't gone more far on this issue. And it seems that we are two caring about that! Everything seems to be ok but maybe there a problem with the Autodesk BindXrefs function. Maybe they'll enhance it for Autocad 2009. Have you seen it! The interface is pretty cool, I should say awesome!
Bert
Cad programmer
Message 11 of 14
BindXrefs function is fine and works great. It doesn't work if I run the scalelist command to reset the scales.
I haven't seen AutoCAD 2009. I'm really waiting to see.
Message 12 of 14
ismailcetin
hi bertyboy,
Your Code is very Successful but i don't understand the row
bSave(bDwg)
Message 13 of 14
This code was very helpful for me, thank you.
But sometimes, i get an error, when binding the xrefs. The error code is 304, Unknown error. I found an error code description, that says, "304 User is disabled", which gives me no clue.
But despite that error, the xrefs are bound. UNLESS they have nested xrefs, in this case, only the main xref is bound, not the nested ones.
Did anyone else come across this problem?
Message 14 of 14
AubelecBE
hi.
have you try to modifiy your :
by
CommandMethod("BindAllXrefs",CommandFlags.Session)> _
i have to use this flag.. I need to save and close the current document. but if i try this the BindXref not working....
”Boost
