.NET
0 Kudos
Post 1 of 14
Bind Xrefs
994 Views, 13 Replies
12-24-2007 01:51 PM
Hi to all. I have'nt seen a lot on xrefs bind. So I've done an effort on my side and wanted to share this code with you. It's a basic Bind Command. You can send me your comments if you wish!
Don't forget to put the < before the commandmethod!!!
Imports Autodesk.AutoCAD
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
CommandMethod("BindAllXrefs")> _
Public Sub BES()
Dim bTransMan As DatabaseServices.TransactionManager
Dim bTrans As DatabaseServices.Transaction
Dim bDwg As Document
Dim bBT As BlockTable
Dim bBTR As SymbolTableRecord
Dim bBTE As SymbolTableEnumerator
bDwg = Application.DocumentManager.MdiActiveDocument
bTransMan = bDwg.TransactionManager
bTrans = bTransMan.StartTransaction
Try
'Open the database for Read
bBT = bDwg.Database.BlockTableId.GetObject(OpenMode.ForRead)
bBTE = bBT.GetEnumerator
Dim XrefIds As New ObjectIdCollection
While bBTE.MoveNext = True
bBTR = bBTE.Current.GetObject(OpenMode.ForRead)
'Check if block is xref and add if so, add it's ID to the ObjectIdCollection
If bBTR.IsResolved And Not bBTR.Name.Contains("|") Then
XrefIds.Add(bBTR.Id)
End If
End While
'Bind xref of collection
bDwg.Database.BindXrefs(XrefIds, True)
'Important to commit
bTrans.Commit()
Catch ex As Exception
MsgBox(ex.Message, MsgBoxStyle.Critical)
Finally
bTrans.Dispose()
bTransMan.Dispose()
End Try
End Sub
0 Kudos
Post 2 of 14
Re: Bind Xrefs
12-24-2007 09:30 PM in reply to: bertyboy
Hi Again! I just wanted to specifie that this code is for Autocad 2008.
And also Merry Christmas to all !!!
Valued Contributor
0 Kudos
Post 3 of 14
Re: Bind Xrefs
01-28-2008 10:17 PM in reply to: bertyboy
Thanks for the code. But I have a question. What if the xrefs are unresolved? How do I handle the unresolved xrefs, like 'Not Found', 'Unloaded', 'Unreferenced'?
0 Kudos
Post 4 of 14
Re: Bind Xrefs
01-29-2008 03:41 PM in reply to: bertyboy
I love good questions!
I'm not an expert on this. But I find out that you could convert the
"SymbolTableRecord" to a "BlockTableRecord" with:
dim BlcTabRec as BlockTableRecord = _ Ctype(YourSymTableRecVariable,BlockTableRecord)
the BlcTabRec have a couple of property you could use.
Like:
IsUnloaded
IsFormExternalReference
IsResolved
But for the:
'Not Found', 'Unreferenced'
I think you could use the "IsResolved" property.
If Not IsResolved(BlcTabRec ) then Msgbox "Problem here!!"
Just for information, there's an automatic Bind command part of the etransmit command in Autocad 2008. That's very cool!
Cad Programmer
Bert
0 Kudos
Post 5 of 14
Re: Bind Xrefs
02-17-2008 10:39 PM in reply to: bertyboy
You're great, man!
What is YourSymTableRecVariable? Could you please help on how that would go into code.
0 Kudos
Post 6 of 14
Re: Bind Xrefs
And why the _?
0 Kudos
Post 7 of 14
Re: Bind Xrefs
02-17-2008 11:19 PM in reply to: bertyboy
Ok...I got it!
Dim BlkTabRec As BlockTableRecord = CType(bBTR, BlockTableRecord)
But unfortunatly it's not working.
0 Kudos
Post 8 of 14
Re: Bind Xrefs
02-18-2008 05:55 PM in reply to: bertyboy
Me it's working very fine. So I send you the code updated.
Oh ya! You guessed right for what you wrote!
Imports Autodesk.AutoCAD.EditorInput
Imports Microsoft.Office.Interop
Imports Microsoft.VisualBasic.ApplicationServices
Imports System.IO
< CommandMethod("BindAllXrefs") > _
Public Sub BES()
Dim bBTRr As BlockTableRecord
' Current Document
Try
' Open the database for Read
bBTRr = CType(bBTR, BlockTableRecord)
' Check if block is xref and also resolved and thenadd its ID to the ObjectIdCollection
If bBTRr.IsFromExternalReference And bBTRr.IsResolved Then
End If
End While
' Bind xref of collection
Try
'We bind all xrefs of drawing
MsgBox("Error: " & ex.Message)
End Try
' Important to commit
bTrans.Commit()
bSave(bDwg)
Finally
bTrans.Dispose()
bTransMan.Dispose()
End Try
End Sub
Maybe if it doesn't work, a error message could help you up!
Cad Programmer
Bert
0 Kudos
Post 9 of 14
Re: Bind Xrefs
04-06-2008 05:21 AM in reply to: bertyboy
After a long gap!
Thanks for the code. I did some modifications in the code to suit my requirements, and it did work fine. But after I run a certain AutoCAD command, I get an error that says 'eWasOpenForWrite'. Seems like the command is opening the database and forgets to close! Is there any workaround that can be done in our code?
0 Kudos
Post 10 of 14
Re: Bind Xrefs
04-07-2008 03:09 PM in reply to: bertyboy
You should be an expert of vb.net by the time! :smileyhappy:
I don't know, I haven't gone more far on this issue. And it seems that we are two caring about that! Everything seems to be ok but maybe there a problem with the Autodesk BindXrefs function. Maybe they'll enhance it for Autocad 2009. Have you seen it! The interface is pretty cool, I should say awesome!
Bert
Cad programmer
