I would like to run a routine that would Bind Insert Xrefs, Explode, Purge All, Zoom Extents and Save the file. I am not very lisp/.net savvy, so I was hoping someone out there could provide me with a routine that does just that.
Thanks in advance!
If you know nothing about programming
1. Just enter the commands at commandline and use a "-" before commands that display a dialog box.
2. Press F2 and copy history
3. Copy and paste in NotePad
4. CleanUp
5. Save as a .scr file
You can drag and drop the file on a open drawing, call it from a tool palette, etc.....
Example of Bind and Purge
Copied from Command Line
Command: -XREF Enter an option [?/Bind/Detach/Path/Unload/Reload/Overlay/Attach] <Attach>: b Enter xref name(s) to bind: * No matching xref names found. Command: -PURGE Enter type of unused objects to purge [Blocks/Dimstyles/Groups/LAyers/LTypes/MAterials/MUltileaderstyles/Plotstyles/SH apes/textSTyles/Mlinestyles/Tablestyles/Visualstyles/Regapps/Zero-length geometry/Empty text objects/All]: a Enter name(s) to purge <*>: Verify each name to be purged? [Yes/No] <Y>: n Deleting block "*U18". Deleting block "*U20". Deleting block "*U23". ... ... ... 3 multileader styles deleted. No unreferenced groups found.
After removing all comand prompts and leaving just commands & keywords
-XREF b * -PURGE a * n
You can try EXPLODEALL.vlx to bind xref and explode them while keep the original color and trim off objects outside the xref clipping boundary.
3wood
