.NET
Best way to View DWF on a form
2 REPLIES 2
Matt S
239 Views, 2 Replies
What's the best way to view a DWF file on a windows form? I don't need to edit anything, just display the contents of a single page dwf file.
2 REPLIES 2
in reply to: Matt S
Windows forms can host activex controls.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5226017@discussion.autodesk.com...
in reply to: Matt S
What about in XP Pro 64 Bit... I cant get the
ExpressViewerDll 1.0 Type Library to show on a form...  This same control
with build and load fine on XP Pro.
See the exeption that is a result:
size=2>System.InvalidOperationException: An error occurred creating the form.
See Exception.InnerException for details.
The error is:  is not a valid
Win32 application. (Exception from HRESULT: 0x800700C1) --->
System.BadImageFormatException:  is
not a valid Win32 application. (Exception from HRESULT: 0x800700C1)
size=2>   at
System.Windows.Forms.UnsafeNativeMethods.CoCreateInstance(Guid& clsid,
Object punkOuter, Int32 context, Guid& iid)
size=2>   at
System.Windows.Forms.AxHost.CreateWithoutLicense(Guid clsid)
size=2>   at
System.Windows.Forms.AxHost.CreateWithLicense(String license, Guid
clsid)
size=2>   at
System.Windows.Forms.AxHost.CreateInstanceCore(Guid clsid)
size=2>   at
System.Windows.Forms.AxHost.CreateInstance()
size=2>   at
System.Windows.Forms.AxHost.GetOcxCreate()
size=2>   at
System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
size=2>   at
System.Windows.Forms.AxHost.CreateHandle()
size=2>   at
System.Windows.Forms.Control.CreateControl(Boolean
fIgnoreVisible)
size=2>   at
fIgnoreVisible)
size=2>   at
System.Windows.Forms.AxHost.EndInit()
size=2>   at
GPS.frmViewED.InitializeComponent() in C:\Documents and
Settings\rlester.GMSINC\My Documents\Visual Studio
2008\Projects\GPS\Forms\Extrusions\frmViewED.Designer.vb:line
113
size=2>   at
GPS.frmViewED..ctor()
size=2>   --- End of inner
exception stack trace ---
size=2>   at
GPS.My.MyProject.MyForms.Create__Instance__(T Instance) in
17d14f5c-a337-4978-8281-53493378c1071.vb:line 190
size=2>   at
GPS.My.MyProject.MyForms.get_frmViewED()
size=2>   at
GPS.frmExtrusions.Dt_ExtrudersDataGridView_CellContentClick(Object sender,
DataGridViewCellEventArgs e) in C:\Documents and Settings\rlester.GMSINC\My
Documents\Visual Studio 2008\Projects\GPS\Forms\Extrusions\frmExtrusions.vb:line
127
size=2>-----------------------------------------------------------------------------------------------------
size=2>System.BadImageFormatException:
is not a valid Win32 application. (Exception from HRESULT:
0x800700C1)
size=2>   at
size=2>   at
size=2>   at
clsid)
size=2>   at
size=2>   at
size=2>   at
size=2>   at
size=2>   at
size=2>   at
fIgnoreVisible)
size=2>   at
fIgnoreVisible)
size=2>   at
size=2>   at
113
size=2>   at
activex controls.
face=Arial size=2>http://www.caddzone.com
size=2>AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
href="http://www.acadxtabs.com">
size=2>http://www.acadxtabs.com
size=2><Matt S> wrote in message
href="news:5226017@discussion.autodesk.com">
size=2>news:5226017@discussion.autodesk.com
size=2>...
file.
”Boost
