.NET
begin programming at VS 2005
1 REPLY 1
wesbird
176 Views, 1 Reply
I've been work at VS 2003 for almost a year and work on some project successfully. I just install VS 2005 standard edition, and got problem to start:
I have both AutoCAD 2006 and 2007 installed on my machine. when I add acdbmgd.dll and acmgd.dll from AutoCAD 2005, VS 2005 always add the ones from AutoCAD 2006. and I got compile error.
when I open xxxx.csproj.user, AutoCAD 2007 ones there.
Is there some configuration I need to change ?
Thank you very much
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
1 REPLY 1
in reply to: wesbird
You need ObjectArx lib. 2007 and Vs2005
VS2005 is compatible with ObjectArx 2007
”Boost
