.NET
.NET
Member
1 Kudo
Post 1 of 10
Batching export to pdf from ACAD problem - C#
1318 Views, 9 Replies
08-01-2012 11:48 PM
Hi everyone!
I've got an exiting problem while trying to batch pdf export.
My task is quite simple: first, look through the drawing (all the lists and model space) and find all dynamic blocks with effective name "SheetGOST", case it's a drawing frame; second, export areas surrounded by those frames to pdf page by page. I've decided that plotting areas via "DWG To PDF.pc3" would be the easiest way.
Practically all the steps made: I get collection of blocks, I know howto print one of them to pdf, and it,s working correctly. The problem is, when I try to plot all the areas in cycle, in output pdf I get num of pages according to num of lists, and only the last area from the list. Test document contains 24 blocks on 3 lists, I get 3 page pdf with 7th, 22th and 24th frame printed..
I ran out of the ideas where I went wrong =(
The code is:
Spoiler
        [CommandMethod("PlotToPdf")]
        static public void MultiSheetPlot()
         Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            Transaction tr = db.TransactionManager.StartTransaction();
            using (tr)
                List<GostBlk> BlocksToPlot = new List<GostBlk>();
                List<Layout> LayList = new List<Layout>();
                GetGostStampCollection(db, ed, tr, ref BlocksToPlot, ref LayList);
                ed.WriteMessage("\nThe number of GOST stamps found: " + BlocksToPlot.Count + "\n\n");
                if (BlocksToPlot.Count < 1) return;
                if (PlotFactory.ProcessPlotState == ProcessPlotState.NotPlotting)
                    PlotEngine pe = PlotFactory.CreatePublishEngine();
                    using (pe)
                        PlotProgressDialog ppd = new PlotProgressDialog(false, BlocksToPlot.Count, true);
                        using (ppd)
                            int numSheet = 1;
                            ppd.set_PlotMsgString(PlotMessageIndex.DialogTitle, "Custom Plot Progress");
                            ppd.set_PlotMsgString(PlotMessageIndex.CancelJobButtonMessage, "Cancel Job");
                            ppd.set_PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage, "Cancel Sheet");
                            ppd.set_PlotMsgString(PlotMessageIndex.SheetSetProgressCaption, "Sheet Set Progress");
                            ppd.set_PlotMsgString(PlotMessageIndex.SheetProgressCaption, "Sheet Progress");
                            ppd.LowerPlotProgressRange = 0;
                            ppd.UpperPlotProgressRange = 100;
                            ppd.PlotProgressPos = 0;
                            ppd.OnBeginPlot();
                            ppd.IsVisible = true;
                            pe.BeginPlot(ppd, null);
                            foreach (GostBlk gblk in BlocksToPlot)
                                ppd.StatusMsgString = "Plotting block " + numSheet.ToString() + " of " + BlocksToPlot.Count.ToString();
                                ppd.OnBeginSheet();
                                ppd.LowerSheetProgressRange = 0;
                                ppd.UpperSheetProgressRange = 100;
                                ppd.SheetProgressPos = 0;
                                PlotInfoValidator piv = new PlotInfoValidator();
                                piv.MediaMatchingPolicy = MatchingPolicy.MatchEnabled;
                                PlotPageInfo ppi = new PlotPageInfo();
                                PlotInfo pi = new PlotInfo();
                                BlockReference blk = gblk.BlockRef;
                                Layout lo = gblk.LayoutRef;
                                Extents3d ext = (Extents3d)blk.Bounds;
                                Point3d first = ext.MaxPoint;
                                Point3d second = ext.MinPoint;
                                ResultBuffer rbFrom = new ResultBuffer(new TypedValue(5003, 1)), rbTo = new ResultBuffer(new TypedValue(5003, 2));
                                double[] firres = new double[] { 0, 0, 0 };
                                double[] secres = new double[] { 0, 0, 0 };
                                acedTrans(first.ToArray(), rbFrom.UnmanagedObject, rbTo.UnmanagedObject, 0, firres);
                                acedTrans(second.ToArray(), rbFrom.UnmanagedObject, rbTo.UnmanagedObject, 0, secres);
                                Extents2d window = new Extents2d(firres[0], firres[1], secres[0], secres[1]);
                                // We need a PlotSettings object based on the layout settings which we then customize
                                PlotSettings ps = new PlotSettings(lo.ModelType);
                                LayoutManager.Current.CurrentLayout = lo.LayoutName;
                                pi.Layout = lo.Id;
                                ps.CopyFrom(lo);
                                // The PlotSettingsValidator helps create a valid PlotSettings object
                                PlotSettingsValidator psv = PlotSettingsValidator.Current;
                                psv.SetPlotWindowArea(ps, window);
                                psv.SetPlotType(ps, Autodesk.AutoCAD.DatabaseServices.PlotType.Window);
                                psv.SetUseStandardScale(ps, true);
                                psv.SetStdScaleType(ps, StdScaleType.ScaleToFit);
                                psv.SetPlotCentered(ps, true); //StdScaleType.StdScale1To1
                                psv.SetPlotConfigurationName(ps, "DWG To PDF.pc3", "ISO_A3_(297.00_x_420.00_MM)");
                                pi.OverrideSettings = ps;
                                piv.Validate(pi);
                                if (numSheet == 1)
                                    pe.BeginDocument(pi, doc.Name, null, 1, true, "c:\\multiblock");
                                pe.BeginPage(ppi, pi, (numSheet == BlocksToPlot.Count), null);
                                pe.BeginGenerateGraphics(null);
                                ppd.SheetProgressPos = 50;
                                pe.EndGenerateGraphics(null);
                                // Finish the sheet
                                pe.EndPage(null);
                                ppd.SheetProgressPos = 100;
                                ppd.PlotProgressPos += Convert.ToInt32(100 / BlocksToPlot.Count);
                                ppd.OnEndSheet();
                                numSheet++;
                            // Finish the document
                            pe.EndDocument(null);
                            // And finish the plot
                            ppd.PlotProgressPos = 100;
                            ppd.OnEndPlot();
                            pe.EndPlot(null);
                else
                    ed.WriteMessage("\nAnother plot is in progress.");
Good - thanks!  What about backgroundplot?
And, finally, working (tested in ACAD2010) code for the problem. In case someone finds it useful:
Spoiler
using System;
using System.Collections.Generic;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Internal.Reactors;
using Autodesk.AutoCAD.PlottingServices;
using Autodesk.AutoCAD.Runtime;
using ACAD = Autodesk.AutoCAD.ApplicationServices.Application;
using ED = Autodesk.AutoCAD.EditorInput.Editor;
namespace Plot2PDF
public class Program : IExtensionApplication
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, EntryPoint = "acedTrans")]
static extern int acedTrans(double[] point, IntPtr fromRb, IntPtr toRb, int disp, double[] result);
List<string> msgs = new List<string>();
public class Blk2Plt
public BlockReference BlockRef;
public Layout LayoutObj;
public void Terminate()
ApplicationEventManager cadWinEvnts = Autodesk.AutoCAD.Internal.Reactors.ApplicationEventManager.Instance();
msgs.Sort();
ED ed = ACAD.DocumentManager.MdiActiveDocument.Editor;
foreach (string msg in msgs)
ed.WriteMessage(msg);
public void Initialize()
static string EffectiveName(BlockReference blkref)
if (blkref.IsDynamicBlock)
using (BlockTableRecord obj = (BlockTableRecord)blkref.DynamicBlockTableRecord.GetObject(OpenMode.ForRead))
return obj.Name;
return blkref.Name;
static void GetBlocksToPlotCollection(Database db, Editor ed, Transaction tr, String BlockName, ref List<Blk2Plt> BlockCol)
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
foreach (ObjectId btrId in bt)
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(btrId, OpenMode.ForRead);
if (btr.IsLayout)
Layout lo = (Layout)tr.GetObject(btr.LayoutId, OpenMode.ForRead);
BlockTableRecord ms = (BlockTableRecord)tr.GetObject(lo.BlockTableRecordId, OpenMode.ForRead);
foreach (ObjectId objId in ms)
Entity ent = (Entity)tr.GetObject(objId, OpenMode.ForRead);
if (!ent.GetType().ToString().Contains("BlockReference")) continue;
BlockReference blk = (BlockReference)ent;
string Effn = EffectiveName(blk);
if (!Effn.ToUpper().Contains(BlockName.ToUpper())) continue;
Blk2Plt theBlk = new Blk2Plt();
theBlk.BlockRef = blk;
theBlk.LayoutObj = lo;
BlockCol.Add(theBlk);
static void PlotBlockColToPDF(String BlockName, String PrinterName, String OutPath, String PaperSize = "ISO_A4_(297.00_x_210.00_MM)")
Object SysVarBackPlot = Application.GetSystemVariable("BACKGROUNDPLOT");
Application.SetSystemVariable("BACKGROUNDPLOT", 0);
using (tr)
List<Blk2Plt> BlocksToPlot = new List<Blk2Plt>();
GetBlocksToPlotCollection(db, ed, tr, BlockName, ref BlocksToPlot);//Getting collection of blocks
ed.WriteMessage("\nThe number of blocks found: " + BlocksToPlot.Count + "\n\n");
using (pe)
using (ppd)
int numSheet = 1;
// Setting up the PlotProgress dialog
ppd.OnBeginPlot();
foreach (Blk2Plt gblk in BlocksToPlot)
// Starting new page
ppd.OnBeginSheet();
Layout lo = gblk.LayoutObj;
// Getting coodinates of window to plot
pi.Layout = lo.Id;
ps.CopyFrom(lo);
psv.SetPlotConfigurationName(ps, PrinterName, PaperSize);
piv.Validate(pi);
if (numSheet == 1) pe.BeginDocument(pi, doc.Name, null, 1, true, OutPath); // Create document for the first page
// Plot the window
// Finish the sheet
pe.EndPage(null);
ppd.OnEndSheet();
numSheet++;
// Finish the document and finish the plot
ppd.OnEndPlot();
pe.EndPlot(null);
ed.WriteMessage("\nPlot completed successfully!\n\n");
else
ed.WriteMessage("\nAnother plot is in progress.\n\n");
tr.Commit();
Application.SetSystemVariable("BACKGROUNDPLOT", SysVarBackPlot);
static public void PlotToPdf()
String BlockName = "SHEETGOST";
String PrinterName = "DWG To PDF.pc3";
String PaperSize = "ISO_A3_(297.00_x_420.00_MM)";
String OutPath = "c:\\plot2pdf";
PlotBlockColToPDF(BlockName, PrinterName, OutPath, PaperSize);
Valued Mentor
30 Kudos
Post 2 of 10
Re: Batching export to pdf from ACAD problem - C#
08-02-2012 08:06 AM in reply to: KoRORland
I assume you never see the message "another plot is in progress"?  Do you make sure "background plotting" is off?
In VB:
Imports acapp = Autodesk.AutoCAD.ApplicationServices
acapp.Application.SetSystemVariable("BACKGROUNDPLOT", 0)
Can you post a sample dwg with "SheetGOST" in it?
Valued Mentor
30 Kudos
Post 3 of 10
08-02-2012 08:14 AM in reply to: fieldguy
We would also need to see your code for "GetGostStampCollection" in order to test.
Member
1 Kudo
Post 4 of 10
08-02-2012 08:31 AM in reply to: fieldguy
Thx for answer!
No, it is plotting sort of corretly - no errors or anything. PlotProgressDialog shows progress for all the frames found. But still output contains only one (last) frame per list. =(
Example file in attachment...
Member
1 Kudo
Post 5 of 10
08-02-2012 08:34 AM in reply to: fieldguy
Oh, my bad. Here it is:
        static void GetGostStampCollection(Database db, Editor ed, Transaction tr, ref List<GostBlk> GostCol, ref List<Layout> LayList)
                if (btr.IsLayout)
                    if (!LayList.Contains(lo)) LayList.Add(lo);
                        string Effn = ACADExtension.ACADExt.EffectiveName(blk);
                        if (!Effn.ToUpper().Contains("SHEETGOST")) continue;
                        GostBlk theBlk = new GostBlk();
                        theBlk.LayoutRef = lo;
                        GostCol.Add(theBlk);
You might need as well my finding block by .EffectiveName:
public static string EffectiveName(BlockReference blkref)
                    return obj.Name;
            return blkref.Name;
 Thanks in advance!
Valued Mentor
30 Kudos
Post 6 of 10
08-02-2012 08:37 AM in reply to: KoRORland
Member
1 Kudo
Post 7 of 10
08-02-2012 08:45 AM in reply to: fieldguy
Whoa! Adding this to the start has done the trick:
Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("BACKGROUNDPLOT", 0);
 That's great! Thank you very much! =) Feeling a little bit mad 'bout myself, though :smileyindifferent:
Valued Mentor
30 Kudos
Post 8 of 10
08-02-2012 08:49 AM in reply to: KoRORland
No problem!  Carry on...
Member
1 Kudo
Post 9 of 10
08-03-2012 12:50 AM in reply to: fieldguy
Spoiler
using System;
namespace Plot2PDF
            msgs.Sort();
                    return obj.Name;
            return blkref.Name;
                if (btr.IsLayout)
            using (tr)
                    using (pe)
                        using (ppd)
                            int numSheet = 1;
                            ppd.OnBeginPlot();
                                ppd.OnBeginSheet();
                                pi.Layout = lo.Id;
                                ps.CopyFrom(lo);
                                piv.Validate(pi);
                                // Plot the window
                                // Finish the sheet
                                pe.EndPage(null);
                                ppd.OnEndSheet();
                                numSheet++;
                            ppd.OnEndPlot();
                            pe.EndPlot(null);
                else
                tr.Commit();
171 Kudos
Post 10 of 10
08-03-2012 01:25 AM in reply to: KoRORland
Thanks for the sharing,
~'J'~
