.NET
Batch Process
1 REPLY 1
aliensinearth
493 Views, 1 Reply
Batch Process
Hi Gentlemen,
Can you please share me a code, to accomplish a list of drawings from a C# list view?
What I want is that,
1. Open each drawing from a list view.
2. Load a lisp file.
3. Save and close drawing.
I am using modeless dialog, Autocad 2013. I tried a lot, but I couldn't do.
I tried with the below code,
public class BatchProcess
        [CommandMethod("BP", CommandFlags.Session)]
        public void GetVolume()
            BatchProcessForm bpf = new BatchProcessForm();
            Application.ShowModelessDialog(bpf);
private void buttonStartProcess_Click(object sender, EventArgs e)
            DocumentCollection acDocMgr = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
            Document doc;
            foreach (ListViewItem lvi in listViewDrawingList.Items)
                string file = lvi.SubItems[1].Text + "\\" + lvi.Text + ".dwg";
                if (File.Exists(file))
                    acDocMgr.Open(file, false);
                doc = acDocMgr.MdiActiveDocument;
                using (DocumentLock lockDoc = doc.LockDocument())
                    string lispFile = "c:\Test\Test.lsp";
                    string commandString = "(load \"" + lispFile + "\") ";
                    doc.SendStringToExecute(commandString, true, false, true);
                doc.CloseAndSave(doc.Name);
Each file is opening one by one properly. Lisp file is not loading. File closes without saving.
Any help please?
1 REPLY 1
rodrigohbm
in reply to: aliensinearth
HOLA AMIGO.
me resulte esto con sharpdevelop vb.net autocad 2015
saludos.
<CommandMethod("rvt1")> _
Public Sub formulario()
Dim form1 As Form1 = New Form1()
'Application.ShowModalDialog(form1)
Autodesk.AutoCAD.ApplicationServices.Application.ShowModelessDialog(form1)
End Sub
Sub Btn_actualizaClick(sender As Object, e As EventArgs)
If Listview2.Items.Count = 0 Then
MessageBox.Show("No hay Datos para actualizar")
Exit Sub
Dim acDocMgr As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
Dim Path As String
Dim I As Integer
Me.Hide
For I = 0 To Listview2.Items.Count - 1
Path= lbl_ruta.Text & (Trim(Listview2.Items(I).Text ))
acDocMgr.Open(Path, False)
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.GetAcadDocument.ZoomExtents()
Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
acDoc.Database.SaveAs(acDoc.Name, True, DwgVersion.Current, acDoc.Database.SecurityParameters)
acDocMgr.MdiActiveDocument.CloseAndDiscard ()
Next I
Me.Show
Listview2.Items.Clear()
End Sub
End Class
”Boost
