.NET
.NET
karea
Message 1 of 5 (233 Views)
Batch process and transaction not declared..
233 Views, 4 Replies
07-02-2013 05:20 AM
Hi:
I have a command to open some dwg files and print them. I´m using the Sub imprimePDF. When I did the code with (AutoCAD 2011 and VS 2008) , it runs ok but now it´s wrong.
This is the sub
Sub imprimePDF()
   Dim myDWG As Autodesk.AutoCAD.ApplicationServices.Document
   myDWG = Application.DocumentManager.MdiActiveDocument
   Application.SetSystemVariable("BACKGROUNDPLOT", 0)
   Using tr As Transaction =   Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()
   Try
       Dim layMgr As LayoutManager = LayoutManager.Current
      Dim loObjId As ObjectId = layMgr.GetLayoutId(layMgr.CurrentLayout)
      Dim lo As Layout = DirectCast(tr.GetObject(loObjId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead), Layout)    error!
end try
end using
end sub
When I´m debugging the code, last sentence produces an error: 'tr not declared'  and I don't know why.
any ideas?
thanks
Actually this is a different issue...
It means that the Transaction and the Layout are not from the same Document.
ADN Support Specialist
augusto.goncalves
Message 2 of 5 (199 Views)
Re: Batch process and transaction not declared..
07-03-2013 06:39 AM in reply to: karea
The code seems ok, so I'm guessing is something with VS
Can you share a print-screen of VS when the error happens?
Augusto Goncalves
Autodesk Developer Network
karea
Message 3 of 5 (192 Views)
07-03-2013 07:17 AM in reply to: augusto.goncalves
here's the display shows,
thanks,
augusto.goncalves
Message 4 of 5 (188 Views)
07-03-2013 07:20 AM in reply to: karea
Augusto Goncalves
karea
Message 5 of 5 (175 Views)
07-03-2013 08:52 AM in reply to: augusto.goncalves
ok!, I've erased the green code and added the blue one and  it runs!
 Dim docMgr As DocumentCollection = Application.DocumentManager
        'Using tr As Transaction = Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()
        Using tr As Transaction = docMgr(1).TransactionManager.StartTransaction()
 Try
                Dim ps As New PlotSettings(False)
