.NET
.NET
Member
Borg21
Message 1 of 6 (340 Views)
Batch embed .tif image into AutoCAD drawings?
340 Views, 5 Replies
08-20-2013 07:22 AM
Due to customer constraints I have to embed .tif images into AutoCAD drawings. This is a manual operation doing a copy ->pastespecial. I was wondering if there was any way to automate this? The pastespecial command doesn't seem to take arguments to bypass the dialoge box and therefore does not allow me to batch embed .tifs programatically.
ADN Support Specialist
fenton.webb
Message 2 of 6 (309 Views)
Re: Batch embed .tif image into AutoCAD drawings?
08-20-2013 05:36 PM in reply to: Borg21
Do you mean open a DWG one by one inside of the AutoCAD editor, or in a side database?
Fenton Webb
Developer Technical Services
Autodesk Developer Network
Member
Borg21
Message 3 of 6 (294 Views)
08-21-2013 03:58 AM in reply to: fenton.webb
If I could do it without opening each individual drawing that would be great but I am sure I am going to have to open each drawing in the editor.
The idea is to write a .NET plugin that will open up a template drawing, insert the tif, save, and then move onto the next one. I just can't have any links to the tif, it must be embedded without path information. That is why I have to use the paste special in the manual operation.
If I can automate getting the tif inside the drawing, the rest is relatively straightforward.
fenton.webb
Message 4 of 6 (280 Views)
08-21-2013 09:09 AM in reply to: Borg21
can you send an example DWG file that shows the result please? Just want to make sure we are on the same page...
Fenton Webb
Member
Borg21
Message 5 of 6 (268 Views)
08-21-2013 09:52 AM in reply to: fenton.webb
Ive attached a sample dwg in a zip file. The drawing contains a titleblock with an embeded tif image using the pastespecial command.
fenton.webb
Message 6 of 6 (258 Views)
08-21-2013 10:21 AM in reply to: Borg21
thanks for sending that... Check out this post http://forums.autodesk.com/t5/NET/How-can-I-insert-rasterImage-but-not-depend-on-the-ori-file/td-p/3...
Fenton Webb
