.NET
Batch build .net solutions - seems unreliable
3 REPLIES 3
JamesMaeding
445 Views, 3 Replies
I have about 10 solutions I need to build every time I tweak a particular library.
I am using VS 2010, all files are C#, no vb or c++ mixed in.
my batch is like:
devenv /build Release "C:\somepath\someprog1.sln"
pause
devenv /build Release "C:\somepath\someprog2.sln"
pause
pause
and they all build "sucessfully", but I sometimes get the message at the end that 1 [project] was skipped.
That is no good. Is it common to have issues with command line compile when IDE works fine on every one?
Is there a more prefereed way to build via batch?
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
3 REPLIES 3
fieldguy
in reply to: JamesMaeding
CADbloke
Fieldguy is on to something with "rebuild". MSBuild / Devenv will skip builds on code that hasn't changed.
Generally the preferred way to batch build .NET stuff is with MSBuild.exe. See http://msdn.microsoft.com/en-us/library/ms164311.aspx and also for a handy way to find the right MSBuild.exe to use in a batch file.
an example from one of my batch files (using the above SO method to find MSBuild) ...
"%MSBUILDDIR%msbuild.exe" "C:\path\solution.sln" /t:build /p:Configuration="Debug " /detailedsummary
Discussions on this galore at https://www.google.com.au/search?site=&source=hp&q=msbuild+devenv&oq=msbuild+devenv
working on all sorts of things including www.tvCAD.tv & www.CADreplace.com
JamesMaeding
in reply to: CADbloke
yah, the rebuild was the issue.
All the documentation focuses on options, the rebuild never occurred to me, thanks all!
”Boost
