.NET
basic error
6 REPLIES 6
678 Views, 6 Replies
basic error
Hi I am creating a new project in VB using the wizard and get a warning that "Load of property 'RootNamespace' failed. The string for the root namespace must be a valid identifier.
When I complie the code, and try to run the command in AutoCAD I get an "Unknow command" error..
The code is
Imports Autodesk.AutoCAD.Runtime
Public Class EvolveClass
' Define command 'Asdkcmd1'
_
Public Sub Asdkcmd1()
' Type your code here
MsgBox("load please load!!")
End Sub
End Class
Can anyone help..
6 REPLIES 6
The two are unrelated. I don't know how to fix the warning, I just started
getting
it myself and haven't figured it out. Look at the post below "Problem
debuging Lab1"
to solve the command line error.
wrote in message news:5324637@discussion.autodesk.com...
The code is
_
End Sub
End Class
Can anyone help..
You problem most likely is caused by different version of .NET version you
use to develop your .NET API program and Acad uses.
By default, Acad uses latest version of .NET, regardless the version .NET
API itself is based on.
If you tell which version of ACAD and which version of VS (or other .NET
development tool, for which version of .NET) you use, it might be help to
solve your problem.
The code is
_
End Sub
End Class
Can anyone help..
As far as the error goes: The only things that recently changed were
uninstalling
Visual Assist X and Ref++. Warning started right after that. Also one of
them was
locking up my machine when starting VS2005 if any other app was running.
I uninstalled them both at the same time so I don't know which it was.
Problem
was gone after the uninstalls.
"Paul Richardson" wrote in message
news:5326543@discussion.autodesk.com...
getting
debuging Lab1"
The code is
_
End Sub
End Class
Can anyone help..
I only currently have 2.0 installed. I even tried explictily adding it to
startup
in 'acad.exe.config' no help.
"Norman Yuan" wrote in message
news:5326519@discussion.autodesk.com...
solve your problem.
The code is
_
End Sub
End Class
Can anyone help..
As far as the WARNING goes: ... oops.
news:5326574@discussion.autodesk.com...
uninstalling
them was
Problem
getting
debuging Lab1"
The code is
_
End Sub
End Class
Can anyone help..
Also, as soon as I close and reopen the project the warning is gone.
news:5326585@discussion.autodesk.com...
startup
solve your problem.
The code is
_
End Sub
End Class
Can anyone help..
”Boost
