.NET
Axdblib (ObjectDBX Common 17.0 Type Lib) is missing or corrupt
3 REPLIES 3
coylet
937 Views, 3 Replies
Arghhhhh.... I had this working yesterday morning. I added the two com references (AutoCAD and AXDBLib) into my VS2005 project and everything was working fine. I ran Inventor for the first time and went back to my project. Now my project will not compile because the Autodesk.AutoCAD.Interop.Common reference could not be found. I deleted and referenced the AXDBLib again and now I have a little ! next to it. Looking at the properties, this reference has no path? I uninstalled AutoCAD and reinstalled. It worked until I ran Inventor again. Any ideas on what is going on? I looked in the GAC and found these two interops but they were version 16 (2006) and I need 17 (2007).
Tom
3 REPLIES 3
in reply to: coylet
This has been a common problem with side-by-side
installations of AutoCAD and Inventor. They step on
each other's ObjectDBX COM registration.
Autodesk is fully aware of it, but doesn't seem to
consider it to be important, so I wouldn't expect to
see a fix any time soon.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5234061@discussion.autodesk.com...
Tom
coylet
in reply to: coylet
Thanks Tony. Do you know of any easy workarounds? I created a project and referenced in the assemblies, marked them as copy local. I plan to keep a copy of these .net assemblies somewhere else and reuse them instead of referencing the com objects directly every time. Any ideas on whether this will work.
Tom
in reply to: coylet
Sorry, I haven't learned of any easy workarounds,
so I would try what you are doing and see if that
works.
Unfortunately, Autodesk still doesn't know how
to distribute products that do not interfere with
other products.
wrote in message news:5234367@discussion.autodesk.com...
Tom
”Boost
