In order to avoid duplicate eventhandlers, I did like the following...
Document doc = Application.DocumentManager.MdiActiveDocument; try { doc.BeginDocumentClose -= new DocumentBeginCloseEventHandler(MyEventHandler); } catch { // Do nothing } doc.BeginDocumentClose += new DocumentBeginCloseEventHandler(MyEventHandler);
The above worked greatly with AutoCAD 2007.
But yesterday I migrated my code into AutoCAD 2010 (with Object ARX 2010).
Unfortunately, it seems like AutoCAD 2010 catches before my code catches it.... (Though I am not sure if this is even make sense)
The evidence...
If I ignore this message, everything works great as it was meant to be...
I am just wondering if I could disable(?) this. Or if there is any other effective work around....
Well, I guess I could just have a global boolean value that checks the status of event attachment.
But would this be the only way?
Solved by Alexander.Rivilis. Go to Solution.
Facebook | Twitter | LinkedIn
Thank you everyone~
@matus: Actually, I just tried and got the same message in production (release) mode.
@Alexander
In fact, the above code was simplified one. I will write it in more detail.
[CommandMethod("CreateObject")] public static void CreateObject() { // Creates a global object MyStaticClass.CreateObject(); // When the current document is closing confirm user whether or not to destroy the object // This event handler is required only after CreateObject is called Document doc = Application.DocumentManager.MdiActiveDocument; try { doc.BeginDocumentClose -= new DocumentBeginCloseEventHandler(MyStaticClass.ConfirmDestroyObject); } catch { // Do nothing } doc.BeginDocumentClose += new DocumentBeginCloseEventHandler(MyStaticClass.ConfirmDestroyObject); } public static class MyStaticClass { ... internal static void ConfirmDestroyObject(object sender, DocumentBeginCloseEventArgs e) { Document doc = sender as Document; ... System.Windows.Forms.DialogResult dr = System.Windows.Forms.MessageBox.Show(msg, "Alert", System.Windows.Forms.MessageBoxButtons.OKCancel); if (dr == System.Windows.Forms.DialogResult.OK) { MyStaticClass.DestroyObject(); } else { e.Veto(); } } }
My case... dose look like the static/shared issue...
or maybe am I missing something??
What about checking event handler was added or no?
P.S.: I've not tested your's code.
This smells like an AutoCAD bug. The same code does not throw any exception on AutoCAD 2014. The only way I see to avoid it is to put a boolean flag somewhere.
If you can make your CreateObject method an instance method, you can store this flag in a field of your command object. You can also use Document.UserData.
