.NET
Avoid Error !
3 REPLIES 3
gilseorin
155 Views, 3 Replies
Avoid Error !
Hi, all.
In my code, when no object to be selected, error occurs.
To avoid this error, what should I add in my code?
3 REPLIES 3
in reply to: gilseorin
Sorry for stating the seemingly obvious ....
... test for the condition or trap the exception.
Refer to the Prompt and Selection Solution examples in the SDK
..\Samples\DotNet folder
/// kwb
wrote in message news:5434546@discussion.autodesk.com...
Hi, all.
gilseorin
Thank you for your information.
It's solved.
And, Pardon my ignorance.
The Status property of the PromptResult based
classes will be set to something other than
ErrorStatus.OK, if no input is provided.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
Hi, all.
”Boost
