.NET
Automate AutoCAD from a website using .NET is it possible?
4 REPLIES 4
klover
350 Views, 4 Replies
Dear All,
I am wondering is it possible to do such thing? if so is there any links for me to study?
Currently I got this project to build a web application and from the web automate the Autocad drawing.
Thanks in advance
Hasegawa
4 REPLIES 4
arcticad
in reply to: klover
There is http://freewheel.autodesk.com/ which is just for viewing and printing.
It may be possible using the http://www.opendesign.com/
(defun botsbuildbots() (botsbuildbots))
fyathyrio8
in reply to: klover
I tried once to no avail. I forget what the exact complication was. It could probably be done, but rather than waste time beating the problem to death, I created a web service. Speaking broadly, I used a web application to get information about what actions needed to be performed. I then created a Windows Forms app that controlled AutoCAD through COM (though not the best way), and queried the web service from the Windows app to retrieve the info.
This might seem like a long way around the bush, but IMO it makes more sense because you don't need to run AutoCAD on your web server.
arcticad
in reply to: klover
Autocad does not license Autocad to run on a server.
That being said it could be done,
By using another API to modify a drawing directly will allow you to have more control and not be limited by AutoCAD being busy.
klover
in reply to: klover
Thanks all for the reply.
arcticad: are there any site where I can get an example?
thanks again
”Boost
