.NET
Autodesk.AutoCAD.Runtime.Exception: eFileInternalErr
3 REPLIES 3
2322 Views, 3 Replies
I get this error when running my "SaveALL" Routine. It worked on AutoCAD Electrical 2012 with WinXP-Pro 32bit.
I just upgraded my PC to Windows 7, 64Bit. (I am using C# 2010)
I  set the platform in project properties to "Active (Any CPU), then recompiled.
Did a Netload "saveall.dll"
Any recommendations?
3 REPLIES 3
Alfred.NESWADBA
I don't think that it is easy to help when we don't see any line of code. At least the line that breaks your debugging/where the exception raises should be made visible to us.
The minimum help I can give at this state is >>>this<<<, sorry!
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
at Autodesk.AutoCAD.DatabaseServices.Database.Save()
at ACAD20121.Class1.SaveAll()
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.261 (RTMGDR.030319-2600)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
AdApplicationFrame
Assembly Version: 0.0.0.0
Win32 Version: 3.2.23.0
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/AdApplicationFrame.DLL
msvcm90
Assembly Version: 9.0.30729.4926
Win32 Version: 9.00.30729.4926
CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_08e1a05ba83fe554/msvcm90.dll
Acdbmgd
Assembly Version: 18.2.0.0
Win32 Version: 18.2.51.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/AcdbMgd.DLL
System
Win32 Version: 4.0.30319.261 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
AdWindows
Assembly Version: 3.2.23.0
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/AdWindows.DLL
PresentationFramework
Win32 Version: 4.0.30319.233
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
Win32 Version: 4.0.30319.233 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
Win32 Version: 4.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
PresentationFramework.Classic
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Classic/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Classic.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Acmgd
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Acmgd.DLL
System.Configuration
Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcWindows
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/AcWindows.DLL
AcCui
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/AcCui.DLL
PresentationFramework.Aero
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
AcWindows.resources
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/en-US/AcWindows.resources.DLL
AceLoader
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Acade/AceLoader.dll
ManagedMC3
Assembly Version: 5.8.0.0
Win32 Version: 5.8.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/ManagedMC3.DLL
AceMonitor
Assembly Version: 9.0.1.1
Win32 Version: 9.0.1.1
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Acade/AceMonitor.dll
AceMigrationUtil
Assembly Version: 6.0.1.1
Win32 Version: 9.0.50.0
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/AceMigrationUtil.DLL
System.Windows.Forms
Win32 Version: 4.0.30319.235 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
AceDBEditor
CodeBase: file:///C:/program%20files/autodesk/acade%202012/acade/AceDBEditor.dll
AceCatalog.WPF.Client
CodeBase: file:///C:/program%20files/autodesk/acade%202012/acade/AceCatalog.WPF.Client.dll
AcXrefUtil
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/AcXrefUtil.DLL
VaAc_startupUI
Win32 Version: 16.0.56.200
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/VaAc_startupUI.arx
vaac_startupUIMgd
Assembly Version: 16.0.56.200
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/vaac_startupUIMgd.DLL
VaAc_addin
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/vaac_addin.arx
vaac_util
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/vaac_util.DLL
VaAc_service
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/vaac_service.arx
Connectivity.Common
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Common.DLL
ContextualTabSelectorRules
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/AcWindows.dll
AcMrUi
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/AcMrUI.DLL
AcMrUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/en-US/AcMrUi.resources.DLL
AcMr
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/AcMr.DLL
System.Runtime.Serialization
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
AceRibbonUtils
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/AceRibbonUtils.DLL
WindowsFormsIntegration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
AceRibbonUtils.resources
Win32 Version: 0.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/en-US/AceRibbonUtils.resources.DLL
AcCustomize
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/AcCustomize.DLL
AcCustomize.resources
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/en-US/AcCustomize.resources.DLL
VaAc_Verticals
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/VaAc_Verticals.arx
Connectivity.Common.Vault
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Common.Vault.DLL
Connectivity.Request.Vault
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Request.Vault.DLL
Connectivity.Request.Common
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Request.Common.DLL
Connectivity.Request.Runtime
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Request.Runtime.DLL
Connectivity.Application.VaultBase
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Application.VaultBase.DLL
Connectivity.Explorer.Framework
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Explorer.Framework.DLL
Connectivity.Request.Foundation
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Request.Foundation.DLL
Connectivity.Proxies.Utils
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Proxies.Utils.DLL
Autodesk.Connectivity.WebServices
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Autodesk.Connectivity.WebServices.DLL
Connectivity.Request.Document
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Request.Document.DLL
Microsoft.Web.Services3
Assembly Version: 3.0.0.0
Win32 Version: 3.0.5305.0
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.Web.Services3/3.0.0.0__31bf3856ad364e35/Microsoft.Web.Services3.dll
System.Web.Services
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Web.Services/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
DWFMergerUtil
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/DWFMergerUtil.DLL
Connectivity.Request.Item
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Request.Item.DLL
Connectivity.Request.ChangeOrder
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Request.ChangeOrder.DLL
Connectivity.Common.Windows
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Common.Windows.DLL
Autodesk.Connectivity.Extensibility.Framework
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Autodesk.Connectivity.Extensibility.Framework.DLL
Connectivity.Explorer.Document.Objects
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Explorer.Document.Objects.DLL
Connectivity.Common.SharedLibCSharp
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Common.SharedLibCSharp.DLL
Connectivity.Explorer.Foundation
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Explorer.Foundation.DLL
Connectivity.Proxies.Security
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Proxies.Security.DLL
DevExpress.XtraBars.v10.1
Assembly Version: 10.1.4.0
Win32 Version: 10.1.4.0
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/DevExpress.XtraBars.v10.1/10.1.4.0__b88d1754d700e49a/DevExpress.XtraBars.v10.1.dll
DevExpress.Utils.v10.1
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/DevExpress.Utils.v10.1/10.1.4.0__b88d1754d700e49a/DevExpress.Utils.v10.1.dll
cfmyjpe1
DevExpress.Data.v10.1
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/DevExpress.Data.v10.1/10.1.4.0__b88d1754d700e49a/DevExpress.Data.v10.1.dll
DevExpress.XtraEditors.v10.1
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/DevExpress.XtraEditors.v10.1/10.1.4.0__b88d1754d700e49a/DevExpress.XtraEditors.v10.1.dll
sy54qv45
Connectivity.Shared.Logging
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Shared.Logging.DLL
Microsoft.Practices.EnterpriseLibrary.Logging
Win32 Version: 4.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Microsoft.Practices.EnterpriseLibrary.Logging.DLL
Connectivity.Common.BatchPlot
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Common.BatchPlot.DLL
Win32 Version:
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Common.SharedLib.DLL
Connectivity.Resolve.ResolveHelper
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/Connectivity.Resolve.ResolveHelper.DLL
AcLayer
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/AcLayer.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/en-US/AcLayer.resources.DLL
UIAutomationProvider
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
AcButterflyExt
Assembly Version: 1.0.0.23
Win32 Version: 1.0.0.23
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/AcButterflyExt.DLL
AcButterflyExt.resources
CodeBase: file:///C:/Program%20Files/Autodesk/Acade%202012/en-US/AcButterflyExt.resources.DLL
SaveAll
CodeBase: file:///C:/VS2010/Projects/SaveAll/SaveAll/bin/SaveAll.dll
AceAddIn
CodeBase: file:///c:/program%20files/autodesk/acade%202012/acade/aceaddin.arx
AceMgdRibbonUtils
Assembly Version: 1.0.4073.43046
CodeBase: file:///c:/program%20files/autodesk/acade%202012/acade/AceMgdRibbonUtils.dll
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
Alfred.NESWADBA
could you try to save to another filename? Just to avoid some file-sharing problems.
Are you sure that there is no DocumentLock or TransAction active when you start saving?
- alfred -
Alfred NESWADBA
”Boost
