.NET
GeeHaa
Message 1 of 10 (999 Views)
Autodesk.AutoCAD.Ribbon
999 Views, 9 Replies
11-26-2013 09:31 AM
Hi
I am trying to associate F1 help to a ribbon button.
I found this article
http://adndevblog.typepad.com/autocad/2012/09/associating-f1-help-with-ribbon-button.html
I am using VB2010 express with AutoCAD 2013. Along with the usual acmgd.dll, acdbmgd.dll, accoremgd.dll, I am referencing AcCui.dll and AdWindows.dll
What I need to know is what reference I need to be able to see Autodesk.AutoCAD.Ribbon in intellisense.
Thanks In advance.
I would suggest using the AutoLoader to deploy your application. The PackageContents.xml can be modified to associate F1 help topics.
http://adndevblog.typepad.com/autocad/2012/04/autoloaderf1-help-integration.html
 But if you need to do this from the CUI dialog, then it can be done by associating an extended help xaml file for your command.
You can find a sample extended help xaml file here :
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a9193826455f5ffba22e1113c6c30c0e-39dc.htm,topicNumber=d0e376084
To associate F1 help, you will need the line in the above post to be modified as
<src:RibbonToolTip x:Key="MYEH_CMD_0002" HelpSource = "ToolTipDemo.chm" HelpTopic = "CreateLayer">
Unfortunately the HelpTopic does not get recognised although the chm opens on pressing F1.
For this we have a request logged with our engineering team.
Balaji
Board Manager
StephenPreston
Message 2 of 10 (978 Views)
Re: Autodesk.AutoCAD.Ribbon
11-26-2013 02:08 PM in reply to: GeeHaa
The Autodesk.AutoCAD.Ribbon namespace is contained within AcWindows.dll.
Cheers,
Stephen Preston
Autodesk Developer Network
GeeHaa
Message 3 of 10 (962 Views)
11-27-2013 12:16 PM in reply to: GeeHaa
Thanks very Much that did the trick. I tried to translate the C# into Vb.net But I'm getting the following error.
Unable to cast object of type 'F1_Help.AdskCommandHandler' to type 'System.Windows.Input.ICommand'.
Any Help would be much appreciated.
  <CommandMethod("CRB")> _
    Public Sub CRB()
        Dim ribCntrl As Autodesk.Windows.RibbonControl = Autodesk.AutoCAD.Ribbon.RibbonServices.RibbonPaletteSet.RibbonControl
        Dim ribTab As RibbonTab = New RibbonTab
        ribTab.Title = "F1 Help Test"
        ribTab.Id = "My_Tab_ID"
        ribCntrl.Tabs.Add(ribTab)
        Dim ribSourcePanel As Autodesk.Windows.RibbonPanelSource = New RibbonPanelSource
        ribSourcePanel.Title = "Controls"
        Dim ribPanel As RibbonPanel = New RibbonPanel
        ribPanel.Source = ribSourcePanel
        ribTab.Panels.Add(ribPanel)
        Dim ribToolTip As RibbonToolTip = New RibbonToolTip
        ribToolTip.Command = "My Command"
        ribToolTip.Title = "My Title"
        ribToolTip.Content = "My Content"
        ribToolTip.ExpandedContent = "my Expanded Content !"
        'enable f1 Help
        ribToolTip.IsHelpEnabled = True
        Dim ribRow1 As RibbonRowPanel = New RibbonRowPanel
        ribRow1.Tag = "Row1"
        Dim ribButton As RibbonButton = New RibbonButton
        ribButton.Text = "PLINE"
        ribButton.ShowText = True
        ribButton.CommandParameter = "\Xlb\Xlb_PLINE"
        ribButton.CommandHandler = New AdskCommandHandler
        ribButton.HelpSource = New System.Uri("C:\Contents\Sample.chm", UriKind.RelativeOrAbsolute)
        ribButton.HelpTopic = "Sanmple"
        ribButton.IsToolTipEnabled = True
        ribButton.ToolTip = ribToolTip
        ribSourcePanel.Items.Add(ribButton)
        ribTab.IsActive = True
    End Sub
End Class
Public Class AdskCommandHandler
    'Implements System.Windows.Input.ICommand
    Public Function CanExecute(ByVal parameter As Object) As Boolean
        Return True
    End Function
    Public Event CanExecuteChanged As EventHandler
    Public Sub Execute(ByVal parameter As Object)
        Dim ribBtn As Autodesk.Windows.RibbonButton = TryCast(parameter, Autodesk.Windows.RibbonButton)
        If ribBtn.CommandParameter.ToString <> "" Then
            Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.SendStringToExecute(ribBtn.CommandParameter.ToString, True, False, True)
        End If
    End Sub
End Class
ADN Support Specialist
Balaji_Ram
Message 4 of 10 (937 Views)
11-30-2013 01:30 PM in reply to: GeeHaa
Can you please try this VB.Net code for the command handler class ?
    Public Function CanExecute(ByVal parameter As Object) _
 As Boolean Implements System.Windows.Input.ICommand.CanExecute
        Return True
    End Function
    Public Event CanExecuteChanged( _
ByVal sender As Object, ByVal e As System.EventArgs) _
Implements System.Windows.Input.ICommand.CanExecuteChanged
    Public Sub Execute(ByVal parameter As Object) _
Implements System.Windows.Input.ICommand.Execute
        End If
    End Sub
End Class
Balaji
Developer Technical Services
GeeHaa
Message 5 of 10 (887 Views)
12-09-2013 07:37 AM in reply to: GeeHaa
Thanks that worked. It creates a new ribbon tab etc. and the chm file comes up when I hit F1 help. But I can't find the tab or panel in the CUI. and if I close AutoCAD and reopen It is gone. Do I need to somehow attach it to a workspace?
Thanks Again.
Balaji_Ram
Message 6 of 10 (864 Views)
12-10-2013 01:51 AM in reply to: GeeHaa
There are two different sets of API to work with ribbons in AutoCAD. The runtime ribbon API and the CUI API. The sample code that is being used here is the ribbon runtime API and the ribbon tabs created using it are not saved in the CUIx file.
When using the runtime ribbon API, it is needed to setup your command for load at AutoCAD startup. This is to ensure that those ribbon tabs get created everytime AutoCAD starts.
Balaji
Balaji
GeeHaa
Message 7 of 10 (840 Views)
12-11-2013 04:21 AM in reply to: Balaji_Ram
Is there a way to associate F1 help to a button using the CUI API? I've been looking through the properties and I don't see anything like helpsource.
If I could do it without a program that would be fine too. At the end of the day what I need is to have a CUIx file where F1 Help for buttons is associated with a CHM file.
Thanks Again
Balaji_Ram
Message 8 of 10 (829 Views)
12-11-2013 08:22 AM in reply to: GeeHaa
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a91938...
Balaji
Balaji
GeeHaa
Message 9 of 10 (820 Views)
12-11-2013 12:09 PM in reply to: GeeHaa
Thanks this is exactly what I needed Thank You!
WolframKuss12
Message 10 of 10 (110 Views)
08-21-2014 06:45 AM in reply to: Balaji_Ram
Any news on this?
