.NET
Active Contributor
bolek75
Message 1 of 3 (274 Views)
Autodesk.AutoCAD.Interop
274 Views, 2 Replies
03-01-2006 04:57 AM
in some sample code I found the using Autodesk.AutoCAD.Interop statement.
Which DLL do I have to reference?
Cheers
bolek75
Distinguished Contributor
dmarcotte4
Message 2 of 3 (274 Views)
Re: Autodesk.AutoCAD.Interop
03-02-2006 05:16 PM in reply to: bolek75
If your using Visual studio, you would import the com reference AutoCAD 200X Type Library, where X is your version of autocad. hope this helps
cgay
Message 3 of 3 (274 Views)
03-03-2006 02:54 PM in reply to: bolek75
I believe that you also need the AutoCAD/ObjectDBX Common x.0 Type Library
C
Need installation help?
