.NET
Autodesk.AutoCAD.Interop
2 REPLIES 2
785 Views, 2 Replies
in some sample code I found the using Autodesk.AutoCAD.Interop statement.
Which DLL do I have to reference?
Cheers
bolek75
2 REPLIES 2
If your using Visual studio, you would import the com reference AutoCAD 200X Type Library, where X is your version of autocad. hope this helps
cgay
I believe that you also need the AutoCAD/ObjectDBX Common x.0 Type Library
C
”Boost
