.NET
.NET
Valued Contributor
mario.rosenbohm
Message 1 of 4 (715 Views)
Autodesk.AutoCAD.Colors.EntityColor.LookUpAci result is wrong
715 Views, 3 Replies
02-13-2013 05:58 PM
i would get the AutoCAD ColorIndex from RGB.
The RGB Color is 165,41,0 is the korrekt RGB from Index 22, but the
"Autodesk.AutoCAD.Colors.EntityColor.LookUpAci" result is Index 27 (RGB 127,31,0)
why?
regards Mario
Valued Mentor
AubelecBE
Message 2 of 4 (704 Views)
Re: Autodesk.AutoCAD.Colors.EntityColor.LookUpAci result is wrong
02-14-2013 04:25 AM in reply to: mario.rosenbohm
Here a code for converting. (I use it for convert color from the Dialog Color in autocad :
Dim fenetre As New Autodesk.AutoCAD.Windows.ColorDialog
            fenetre.Color = Autodesk.AutoCAD.Colors.Color.FromRgb(Red as byte,green as byte, blue as byte)
            fenetre.IncludeByBlockByLayer = False
            If fenetre.ShowDialog() = Windows.Forms.DialogResult.OK Then
                Dim CouleurR As Byte
                Dim CouleurB As Byte
                Dim CouleurV As Byte
                If fenetre.Color.IsByAci = False Then
                    CouleurR = fenetre.Color.Red
                    CouleurB = fenetre.Color.Blue
                    CouleurV = fenetre.Color.Green
                Else
                    'conversion
                    'Get the rgb values from the index
                    Dim colIndex As Integer
                    colIndex = fenetre.Color.ColorIndex
                    Dim bytes() As Byte = BitConverter.GetBytes( _
                            Autodesk.AutoCAD.Colors.EntityColor.LookUpRgb(colIndex))
                    CouleurR = bytes(0)
                    CouleurB = bytes(2)
                    CouleurV = bytes(1)
                End If
                ' here uour code for use the var CouleurR, ..B, ...V
            End If
--> replace Red, green and blue  with your data.
Alfred.NESWADBA
Message 3 of 4 (698 Views)
02-14-2013 04:44 AM in reply to: mario.rosenbohm
Hi Mario,
the only thing I know with differences between calculation of ACI <> TrueColor is that the background of AutoCAD changes the result of the calculation. So it's different for AutoCAD if you are working with black of white AutoCAD-background.
I'm not sure if this special function is also depending on the background, but at least you might try it both states of background just to verify it (on CAD-de there was also such a thread if you want to search there).
- alfred -
Alfred NESWADBA
Valued Contributor
mario.rosenbohm
Message 4 of 4 (678 Views)
02-14-2013 12:27 PM in reply to: mario.rosenbohm
i make a litle workaround and this get the korrekt ACI-Color
        public static Autodesk.AutoCAD.Colors.Color getAutoCADColorFromMediaColor(System.Windows.Media.Color defaultColor)
            if (defaultColor != null)
                Autodesk.AutoCAD.Colors.Color colorIndex;
                Autodesk.AutoCAD.Colors.Color colorARGB = Autodesk.AutoCAD.Colors.Color.FromColor(System.Drawing.Color.FromArgb(defaultColor.A,
                                                          defaultColor.R, defaultColor.G, defaultColor.B));
                for (byte i = 0; i <= 255; i++)
                    colorIndex = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByAci, i);
                    if (colorIndex.ColorValue.A == colorARGB.ColorValue.A)
                        if (colorIndex.ColorValue.R == colorARGB.ColorValue.R)
                            if (colorIndex.ColorValue.G == colorARGB.ColorValue.G)
                                if (colorIndex.ColorValue.B == colorARGB.ColorValue.B)
                                    return colorIndex;
                return colorARGB;
            else
                return Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.None, 7);
 regards Mario
