The following is the message that I've been getting when trying to run my application:
FileNotFoundException was unhandled
The specified module could not be found. (Exception from HRESULT: 0x8007007E)
In my application, which runs independently, i am finding an instance of autocad(or creating if it does not exist), opening a drawing, and then editing the drawing using code from a different working application (altered slightly) to edit the drawing.
I am able to open autocad and the drawing with no problem, but trying to run the other code runs in to lots of issues.
At first I thought my issues were regarding mdiActiveDocument, since autocad is minimized once the drawing is opened, but as I've been exploring what is wrong I've relized that it is the entire acadApp (using acadApp = Autodesk.Autocad.ApplicationServices.Application) reference is causing issues. I used this multiple times in the original code and I have all the same references both in the drawing and the solution, yet it still is not working.
I've pretty much ran out of ideas for how to fix this, any help would be greatly appreciated!
Here's some code (let me know if you need anything more):
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using System.Data.SqlClient;
using System.IO;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
private void genButton_Click(object sender, EventArgs e)
// Start AutoCAD
const string progID = "AutoCAD.Application.18";
AcadApplication acApp = null;
try
acApp = (AcadApplication)Marshal.GetActiveObject(progID);
catch
try
Type acType = Type.GetTypeFromProgID(progID);
acApp = (AcadApplication)Activator.CreateInstance(acType, true);
catch
MessageBox.Show("Cannot create object of type \"" + progID + "\"");
if (acApp != null)
acApp.Visible = true;
// Open the drawing (starting with Gen1) that is going to be used.
string strFileName = @"C:\fileName.dwg"
acApp.ActiveDocument.Close();//close initial blank document
if (File.Exists(strFileName))
acApp.Documents.Open(strFileName, false);
acApp.WindowState = AcWindowState.acMin; //Minimize the window so it's not in the way
//DocumentCollection acDocMgr = acadApp.DocumentManager; //causes error
//if (File.Exists(strFileName))
// acDocMgr.Open(strFileName, false);
//else
//acDocMgr.MdiActiveDocument.Editor.WriteMessage("File " + strFileName + " does not exist.");
Auto105 a105 = new Auto105();
a105.executeSave(database);
//acApp.Documents.Close();
//acApp.Quit();
//--From Auto105 class:
public void executeSave(string DB)
database = DB;
LoadBlockIDs();
SaveBlocks();
SaveDrawing();
private void LoadBlockIDs()
blockIds = new string[10];
numBlocks = 0;
//Again the following lines are causing the error (with my adjustments to make it this far)
Document acDoc = acadApp.DocumentManager.MdiActiveDocument;
Database acCurDb = acDoc.Database;
Thanks again for any help!!!
You're trying to use the AutoCAD managed API from another application.
You can't do that. It can only be used in a NETLOADed DLL.
Is there a way I can use my NETLOADed .dll from this application then?
Like trigger the .dll to start a command in Autocad?
That would work for my purposes; essentially I'm automating an application I already have working so it would do same/similar code just without the dialog boxes
The only way to talk to a NETLOADed dll from another process is to
use ActiveX. You make the NETLOADed dll an ActiveX server and
you access it from aother process using the AcadApplication's
GetInterfaceObject() method.
Thanks for your advice and prompt replies. I think what I will end up doing is making this an automated process which runs inside of AutoCAD, rather than a standalone application. That seems to be much easier for me , and shouldn't be much of a hassle for our engineers and drafters.
