.NET
AutoCAD2013 - SaveAs method doesn't work correctly
10 REPLIES 10
Message 1 of 11
mobj
1819 Views, 10 Replies
When using the SaveAs method: db.SaveAs(dwgfile.FullName, true, DwgVersion.AC1024, null); I get some strange results: 1: No .BAK files are created 2: When the saved DWG files are used as reference files, the reference manager freezes if another user has the reference open. When saving the reference DWG file using standard AutoCAD SAVE command, it works correctly again. See code: using System; using System.Collections.Generic; using System.Linq; using System.Text; using System.IO; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.Runtime; namespace ExtractObjects { public class Commands { [CommandMethod("RDKPURGEFILES")] static public void cmdRdkPurgeFiles() { Document doc = Application.DocumentManager.MdiActiveDocument; Editor ed = doc.Editor; PromptStringOptions pStrOpts = new PromptStringOptions("\nEnter filepath: "); pStrOpts.AllowSpaces = true; PromptResult pStrRes = ed.GetString(pStrOpts); if (pStrRes.Status == PromptStatus.OK) // check valid string input { ed.WriteMessage("Filepath is: {0}", pStrRes.StringResult); string filepath = pStrRes.StringResult; DirectoryInfo d = new DirectoryInfo(filepath); foreach (var dwgfile in d.GetFiles("*.dwg", SearchOption.TopDirectoryOnly)) { ed.WriteMessage("\nStart file: " + dwgfile.Name); // Create a database and try to load the file Database db = new Database(false, true); using (db) { try { db.ReadDwgFile(dwgfile.FullName,FileOpenMode.OpenForReadAndAllShare,true,null); // open the dwg file ObjectIdCollection ids = new ObjectIdCollection(); Transaction tr = db.TransactionManager.StartTransaction(); using (tr) { DBDictionary matDict = (DBDictionary)tr.GetObject(db.MaterialDictionaryId, OpenMode.ForRead, false); foreach (DBDictionaryEntry entry in matDict) { string key = entry.Key; if ((key != "ByBlock") && (key != "ByLayer") && (key != "Global")) ids.Add(entry.Value); } db.Purge(ids); foreach (ObjectId id in ids) { DBObject obj = (DBObject)tr.GetObject(id, OpenMode.ForWrite); obj.Erase(); } tr.Commit(); ed.WriteMessage("\nMaterials purged in: " + dwgfile.FullName); db.SaveAs(dwgfile.FullName, true, DwgVersion.AC1024, null); // save as dwg2010 and create a BAK file } } //try catch (System.Exception e) { ed.WriteMessage("\nUnable to access file:" + dwgfile.FullName); ed.WriteMessage("\nException is: " + e.Message); db.Dispose(); // close transaction } //db.Dispose(); // close transaction } // end db } // end foreach } // end if else { ed.WriteMessage("Invalid string input: " + pStrRes.Status.ToString()); } } //end method } }
Morten Bastue Jacobsen
Rambøll Danmark A/S
www.ramboll.dk
10 REPLIES 10
Message 2 of 11
Alfred.NESWADBA
in reply to: mobj
SAVEAS never creates a BAK as it is a new filename and it let's the old/previous DWG unmodified, so no need for a BAK ... only the SAVE (without "...AS") creates a BAK.
Can you upload two drawings? One saved by your .NET routine and another one saved from your AutoCAD manually?
BTW: what AutoCAD version do you use, if you have a vertical product, which one, and last but not least what servicepack?
- alfred -
PS: your code is not readable here, if you want anyone to try it (without editing it a lot) then upload the sourcefile, that's easier for helpers!
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 3 of 11
mobj
in reply to: Alfred.NESWADBA
>SAVEAS never creates a BAK as it is a new filename and it let's the old/previous DWG unmodified, so no need for a BAK ... only the SAVE (without >"...AS") creates a BAK.
Then I don't understand the reference guide. 🙂
"[MarshalAs(UnmanagedType.U1)] bool bBakAndRename
 Input bool indicating whether or not to create a .bak file and change document name in AutoCAD"
I'm saving the file using the same filename, thus overwriting the existing file. So I'm expecting a .BAK file. Similar to SAVEAS from AutoCAD.
I'm not sure of the SAVE() method, as I need to specifiy the file format.
I've uploaded two files. One file that has been processed using the code, and the other is a AutoCAD SAVEAS of the processed file.
I'm using AutoCAD2013 iwth the latest ServicePack. Also ACA2013 is installed, but I'm starting acad.exe without the ACA loaded.
>- alfred -
Yes, I know... But I have some problems with formatting the text.. I'll try to upload the code.
Rambøll Danmark A/S
www.ramboll.dk
Message 4 of 11
Alfred.NESWADBA
in reply to: mobj
Sorry, I didn't think about that you use SAVEAS but let the filename be the same (.SAVE would be enough) 😉
 To your code (haven't tried it yet) .. does it fall into the exception handling? If so you are trying to .Dispose the database twice. that the only thing I saw with a short look to it.
- alfred -
PS: great you got the text here working with FF (I'm running FF too).
Alfred NESWADBA
Message 5 of 11
mobj
Well, when using .SAVE() I now get an "eFileInternalErr" exception...
-edit: the explanation for the error is here: http://forums.autodesk.com/t5/NET/Database-Save-and-eFileInternalErr/td-p/2140848
No, I don't get any exceptions when using the SAVEAS method. Also the .dispose method is outcommented outside the Catch section. So it's not used.
- Morten -
Rambøll Danmark A/S
www.ramboll.dk
Message 6 of 11
Alfred.NESWADBA
in reply to: mobj
.Dispose is done at the end of "Using xxx", so the additional db.Dispose in the catch area would be the one that is to much (but at least I'm not sure if the end of "Using" might be checking that, I'm not working with "Using" statement).
Do you have a drawing before your code was running over it, for the moment I have not seen any difference between those 2 drawings except of the current view.
Oops, do you get that error always or only with some specific DWG files?
What happens if you open a new empty drawing and do the same workflow?
- alfred -
Alfred NESWADBA
Message 7 of 11
Alfred.NESWADBA
in reply to: mobj
and one additional idea: you run the .SAVEAS before the transaction is disposed, it might be more save to do the save afterwards.
- alfred -
Alfred NESWADBA
Message 8 of 11
mobj
>.Dispose is done at the end of "Using xxx", so the additional db.Dispose in the catch area would be the one that is to much (but at least I'm not sure if >the end of "Using" might be checking that, I'm not working with "Using" statement).
Ok, I'll have a look at that..
>Do you have a drawing before your code was running over it, for the moment I have not seen any difference between those 2 drawings except of the >current view.
Yup. I've attached the original drawing. Also, I can't see any difference btw. the two drawings.
I don't know. I've just tested this with the current drawing.
Good idea! I'll try the .SAVEAS before disposing the transaction as well as after so see if there's any difference
Rambøll Danmark A/S
www.ramboll.dk
Message 9 of 11
mobj
in reply to: mobj
I think I've found the solution to one of the problems - Reference Manager freezes when the reference file is open at another user.
Before .SAVEAS, you need to generate/enable previewbitmap.
So, when inserting this line:
db.RetainOriginalThumbnailBitmap = true;
before:
The dwg files seems to work, when used as a reference. Smiley Happy
Now, the remaining problem:
I want the .SAVEAS to create a .BAK file when overwriting the existing DWG file.
Rambøll Danmark A/S
www.ramboll.dk
Message 10 of 11
Balaji_Ram
in reply to: mobj
Hi Morten,
The "bBakAndRename" parameter of the SaveAs method is only applicable while saving the document that is already open in AutoCAD.
If you try this code after you open a drawing in AutoCAD, you will find a .bak file getting created.
doc.Database.SaveAs(doc.Name, true, DwgVersion.AC1024, null);
If it is not open in AutoCAD, you can create a backup of the database just after the ReadDwgFile without relying on SaveAs.
Balaji
Developer Technical Services
Autodesk Developer Network
Message 11 of 11
mobj
in reply to: Balaji_Ram
Thanks!. I was not sure about the difference between reading the DWG file into a new database using:
db.ReadDwgFile
or loadning the file into AutoCAD using:
Document doc = Application.DocumentManager.Open
Rambøll Danmark A/S
www.ramboll.dk
”Boost
