.NET
AutoCad2010 with Visualstudio-2008 (c#)
4 REPLIES 4
giskumar
1476 Views, 4 Replies
Hi All,
I tried to write a simple program in c#.net for autocad 2010.
I build and loaded the .dll file but not able to access the command.
When i type tst in command prompt, it prompting unknown command.
Please help  me how to solve this.
using System;
using System.Collections.Generic;
using System.Text;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using System.Windows.Forms;
using System.Data.OleDb;
using System.Data;
namespace AcadGlobles
    class Commands
        [CommandMethod("tst")]
        static public void test()
            MessageBox.Show("hi");
Kumar.
4 REPLIES 4
It is look like you do not assign Copy Local to False for AutoCAD DLL references in your solution (acmgd.dll, acdbmdg.dll, etc.)
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Jeff_M
in reply to: giskumar
The class Commands needs to be public. Not sure if it matters, but normally the public is the first item listed, so instead of
it woul be
public static void test()
Jeff_M, also a frequent Swamper
Like Jeff said, the method and the class must be public, otherwise AutoCAD will not locate the method
class Commands
should be replaced with
public class Commands
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
giskumar
Hi All,
Thanks for the reply.
Adding Public before class is working for me.
Kumar.
”Boost
