.NET
Autocad with C#
3 REPLIES 3
ozkan_0712
1080 Views, 3 Replies
Autocad with C#
Hi.
I'm a profession Autocad user and I get a help my friend who profession about C#.
I'm a begineer about AutoCad and programming. I succeed to commenation C# and autocad.  (like DevTv "Hello World")
I need a C# codes for Autocad 2012 programming.  I mean is that same codes Visual Basic for Application codes and C# codes? (like class)
Also I need a advice about this subject.
Thanks for helpings..
Tags (2)
3 REPLIES 3
Mike.Wohletz
in reply to: ozkan_0712
Have you downloaded the ObjectARX developer kit and looked at the samples? Also try the following links:
http://through-the-interface.typepad.com/
http://exchange.autodesk.com/autocad/enu/online-help/browse#WS1a9193826455f5ff2566ffd511ff6f8c7ca-48...
ozkan_0712
Hi.
Thanks for helping.
Yes, We download objectarx Documentation and  Download Complete ObjectARX SDK.
We looked and studied about it. But I think our problem is that I and my friend work different area. I'm a designer. He is a programmer.
We made some codes that use Visual Basic for application(in Autocad Tool box) and it worked.But we need to more detail about it.
For example:
SolidSelection.Select acSelectionSetAll
This code is the same use C sharp. ?
If TumPar.Count <> 0 Then
With TumPar
For xp = 1 To .Count
.Remove (1)
Next xp
End With
End If
On Error Resume Next
ThisDrawing.SelectionSets("SS01").Delete
Set SolidSelection = ThisDrawing.SelectionSets.Add("SS01")
grpCode(0) = 0
dataVal(0) = "3DSOLID"
SolidSelection.Select acSelectionSetAll, , , grpCode, dataVal
N = SolidSelection.Count
MsgBox "countyourdrawing: " & N
Posted code is VBA-code. This link can help you to migrate to VB.NET:
http://through-the-interface.typepad.com/through_the_interface/2010/05/more-translated-autocad-vba-t...
Facebook | Twitter | LinkedIn
Expert Elite Member
”Boost
