.NET
AutoCad Script Files
4 REPLIES 4
ajoshi1967
879 Views, 4 Replies
I need Help on Following :
1. Is it possible to read excel files through script files.
2. Can I declare variables in script files.
4 REPLIES 4
mzakiralam
in reply to: ajoshi1967
Please mention clearly what do you want. Only then someone can help you.
hgasty1001
If by script you mean AutoCAd .scr files, the short answer is NO, scripts are just a list of AutoCAd commands that execute almost unconditionally (there is no if ..then else, goto, or things alike)  and with some limitations, but scipts can call AutoLISP code or a VBA macro to execute, and both can access excel files.
Gaston Nunez
ajoshi1967
in reply to: hgasty1001
Thanks a lot Mr. Nunez.
This exactly what I wanted. I have a full fledge program in Autocad VBA. Different offices of our company uses different version of Autocad. So we want have a programming tool which will be independent of version of Autocad. Do you think script files can be better choice.
Can you send me sample code script file which can access vba code
hgasty1001
It's just a line in a text file, put this line : -vbarun SomeAutoCADVBAMacro in a txt file with scr extension and voila.
Gaston Nunez
”Boost
