.NET
Autocad programming using .net
5 REPLIES 5
397 Views, 5 Replies
Hai everyone iam new to programming autocad using c# when i was running some code in microsoft visual c# 2005 express in class library applications i am not getting any out put and iam getting error as "A project with an output type of class library cant be started directly. In order to debug this project,add an executable to this solution which refernces the library project.Set the executable project as the start up project" plz any one help me what to do about this
5 REPLIES 5
Project Properties, Debug page, select "Start external program",
and specify acad.exe as the program to start.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5738794@discussion.autodesk.com...
what SDK u use for the programming If u use ObjectARX then
u install that sdk which can easily incorporate into user visual studio
Hi
since u r project is of type class library. u have two options either u can open autocad through u r application itself or else u can build u r application and load the application dll and execute the command method at autocad command prompt by opening autocad manually.
to open autocad through .net application got to project properties ->Debug->Start External Programme ,here browse the acad.exe.
Then in Application tab select output type as Class library
Hi i am doing a parametric program using VBA,Vlisp,AutoCAD. am converting to Vb.Net and CAD2006. can you please help me to insert the external drawings (sideview.dwg, Topview.dwg) in active drawing file Using VB.Net......
It will help me a lot
Thanks in Advance
Hai even iam new to this field iam sorry
”Boost
