.NET
Autocad pan window in c#.net
1 REPLY 1
664 Views, 1 Reply
In my c#.net windows application, i require two pan windows.For example, left_pan & right_pan.
left_pan window is a smaller one,which contains a dwg image file and a rectangle will hover on it.
In right_pan window,i want to zoom the dwg area covered by rectangle in left_pan.
For more information, please find the attached jpg file, which is my requirement.
Please let me know, how can i do this.
Vijay
1 REPLY 1
fenton.webb
You need to use the classes defined in Autodesk.AutoCAD.GraphicsSystem namely Device, Model and View. Have you seen the BlockView sample? http://through-the-interface.typepad.com/through_the_interface/2008/06/autocad-net-ver.html
Fenton Webb
AutoCAD Engineering
”Boost
