.NET
.NET
Valued Contributor
mnav
Message 1 of 7 (236 Views)
autocad overwrite raster image file while host drawing is open
236 Views, 6 Replies
08-09-2012 01:54 AM
Hi
 i am trying to overwrite the raster image file to an updated version of same file. when i try to copy file it says file is in use by another process IOException.
i can change the path to new loaction and reload image but cant overwite the file at same location.
is there any way to overwite the raster image file while the host drawing is open.
i am using c# and autocad 2010
thanks
Nav
Hallex
Message 2 of 7 (233 Views)
Re: autocad overwrite raster image file while host drawing is open
08-09-2012 02:09 AM in reply to: mnav
Have a look at this article:
http://adndevblog.typepad.com/autocad/2012/07/getset-image-paths-in-drawing-using-net-api.html
~'J'~
Valued Contributor
mnav
Message 3 of 7 (232 Views)
08-09-2012 02:21 AM in reply to: Hallex
thanks for your reply.
i can change the location of  image file without any problem. Error IoException comes if i try to overwite the image file which already in used in open drawing.
i am looking for a way to overwite image file like we can do in drawing Xrefs we can change the source file even though its open in drawing. Autocad just pop a message that an updated version of xref is avialable. but in raster image case its not allowing to update file.
thanks
Hallex
Message 4 of 7 (226 Views)
08-09-2012 02:31 AM in reply to: mnav
If you see new image as available, try add this code block
to know if it's non-unreferenced:
        RasterImage.EnableReactors(true);
        myraster.AssociateRasterDef(imageId);
       tr.commit();
Valued Contributor
mnav
Message 5 of 7 (222 Views)
08-09-2012 02:49 AM in reply to: Hallex
thanks i will give it a go. but problem comes before setting any flags when overwiting file.
Valued Contributor
mnav
Message 6 of 7 (219 Views)
08-09-2012 03:05 AM in reply to: mnav
for eample if Rasterimage location is C:\MyFiles\image1.bmp and if i download the image1.bmp again on same location i got IOException saying file is already in use. file access error.
i am downloading the file programatically on update image button.
if file dont exist already my code works fine download the file and load it into the drawing. problem comes if file alredy exist and refrenced into drawing.
hope this will explain little bit more.
Hallex
Message 7 of 7 (197 Views)
08-09-2012 10:37 AM in reply to: mnav
See if this code is working for you, tested on A2010 especially
       //  original code:
        //  http://adndevblog.typepad.com/autocad/2012/07/getset-image-paths-in-drawing-using-net-api.html
        [CommandMethod("imagePath")]
        public void EditImagePath()
            Database db = HostApplicationServices.WorkingDatabase;
            Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
            PromptEntityOptions peo = new PromptEntityOptions("\nSelect an Image");
            peo.SetRejectMessage("\nSelected entity must be an image.");
            peo.AddAllowedClass(typeof(RasterImage), false);
            PromptEntityResult per = ed.GetEntity(peo);
            if (per.Status != PromptStatus.OK)
                return;
            ObjectId imageId = per.ObjectId;
            try
                using (Transaction trans = db.TransactionManager.StartTransaction())
                    RasterImage myImage = trans.GetObject(imageId, OpenMode.ForRead) as RasterImage;
                    RasterImageDef imageDef = trans.GetObject(myImage.ImageDefId, OpenMode.ForWrite) as RasterImageDef;
                    ed.WriteMessage(imageDef.ActiveFileName);
                    imageDef.SourceFileName = @"C:\Test\jela.bmp";
                    imageDef.ActiveFileName = @"C:\Test\jela.bmp";
                    myImage.UpgradeOpen();
                    myImage.Name = "jela";
                    //imageDef.LocateActivePath();// optional, has no affect in this context
                    imageDef.Load();
                    myImage.AssociateRasterDef(imageDef);
                    trans.Commit();
            catch (System.Exception ex)
                ed.WriteMessage(ex.Message);
~'J'~
