.NET
Active Contributor
DesignProQuig
Message 1 of 11 (236 Views)
Autocad objects coloured rgb disappear on mouse over
236 Views, 10 Replies
09-24-2012 04:04 AM
Hi there,
I if I add an object, let's say a line to the DB.  And colour it with an
RGB (255, 255, 255) value.  When I hold the mouse over the line,
it disappears.  Move the mouse off the line and it re-appears.
Any-one know why?
Cheers,
Martin.
http://www.designprosoftware.co.uk/
Alfred.NESWADBA
Message 2 of 11 (234 Views)
Re: Autocad objects coloured rgb disappear on mouse over
09-24-2012 04:15 AM in reply to: DesignProQuig
what happens if you disable SELECTIONPREVIEW?
- alfred -
Alfred NESWADBA
Active Contributor
DesignProQuig
Message 3 of 11 (231 Views)
09-24-2012 04:19 AM in reply to: Alfred.NESWADBA
Hi Alfredm,
no change I'm afraid :-(.
Alfred.NESWADBA
Message 4 of 11 (226 Views)
09-24-2012 04:31 AM in reply to: DesignProQuig
Hi.
can you upload this drawing? And what version of AutoCAD plus what background-color do you use?
- alfred -
Alfred NESWADBA
Active Contributor
DesignProQuig
Message 5 of 11 (222 Views)
09-24-2012 04:35 AM in reply to: Alfred.NESWADBA
I have my BG set to Black.  After your last post I changed it to red to try it out.  And it works as normal.  But I need the background to be black.
Ta,
Maritn.
Alfred.NESWADBA
Message 6 of 11 (219 Views)
09-24-2012 04:39 AM in reply to: DesignProQuig
Oops, when I open your drawing the line is green (RGB = 87,189,55), do you have a problem with your monitor or gc?
Try this drawing on another workstation, just to verify!
- alfred -
Alfred NESWADBA
Valued Mentor
DiningPhilosopher
Message 7 of 11 (199 Views)
09-24-2012 11:10 AM in reply to: Alfred.NESWADBA
There is no problem with his monitor.
This is a bug.
When SELECTIONPREVIEW = 1 (dash only), objects with RGB colors disappear completely.
Alfred.NESWADBA
Message 8 of 11 (195 Views)
09-24-2012 11:18 AM in reply to: DiningPhilosopher
>> This is a bug.
I have set my background to black, I draw a line with true-color 255,255,255, I set the SELECTIONPREVIEW to 1 and to dashed-only-mode ==> when I move my mouse over the line it does not disappear.
And as the OP stated that he tried also to disable SELECTIONPREVIEW I don't think this is an issue based on that.
Well, I have SP1.1 installed, maybe that's a difference?
- alfred -
Alfred NESWADBA
Valued Mentor
DiningPhilosopher
Message 9 of 11 (185 Views)
09-24-2012 12:31 PM in reply to: Alfred.NESWADBA
After having a closer look, It may not be a bug in AutoCAD, because it only happens here when using hardware-accelerated graphics. When I disable that, the line is drawn correctly. The system I noticed the issue with is using an ATI Radeon consumer graphics card and driver, so that's most-likely where the problem is.
Active Contributor
DesignProQuig
Message 10 of 11 (179 Views)
09-24-2012 01:41 PM in reply to: DiningPhilosopher
I have just turned hardware accelaration off in options and your right it fixes it.  Not sure how I can leave this off as CAD slows to a crawl.
Thanks loads & DOH at the same time!
