.NET
Autocad not seeing Command Methods in new VB.net class
2 REPLIES 2
ralstogj
636 Views, 2 Replies
Hi
I have an exisitng project that I have added a new class to and then inserted the following code for
a new custom command as per the basic tutorial
    Imports Autodesk.AutoCAD.Runtime
Public Class Class1
        <CommandMethod("HelloWorld")> _
        Public Sub HelloWorld()
            MsgBox ("hello")
        End Sub
    End Clas
When I debug and netload the solution autocad does not see the new custom command in the new class
but sees the existing commandmethods in older classes. What am I missing?
Regards
Justin Ralston
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
2 REPLIES 2
ralstogj
in reply to: ralstogj
Found the problem in the other class from the shipped pipe example
it had a line similar to this with the CommandClass
[assembly: CommandClass(typeof(Test.Test))]
which is discussed here
http://www.theswamp.org/index.php?topic=20708.0
not sure what it does but commented it out and now all the command methods work in all classes.
Justin Ralston
Regards
Justin Ralston
chiefbraincloud
Declaring a Class as a CommandClass tells AutoCAD to look there for command methods and causes AutoCAD to not look anywhere else in that assembly.  It is all about loading speed.
”Boost
