.NET
AutoCAD MEP: How to set a property definition display order
2 REPLIES 2
Keith.Brown
750 Views, 2 Replies
I am programmatically creating several property defintions inside of a property set definition.  I would like to be able to set the display order of the property definitions but the property is read only.  Has someone been able to accomplish this using the API?
2 REPLIES 2
Keith.Brown
in reply to: Keith.Brown
I figured out how to do it.
After creating the property defintion you can set the order using something like this.
propertySetDefinition.SetDisplayOrder(formulaPropertyDefinition, 3);
i was trying to set the order using the property definition instead of the property set definition.
timshepherd
Keith,
Many thanks!
I too was looking for the solution in the PropertyDefinition object.
Spot on.
”Boost
