.NET
SENL1362
Message 1 of 3 (182 Views)
AutoCAD MAP end of loading AEC modules
182 Views, 2 Replies
12-06-2013 07:20 AM
AutoCAD MAP loads a some AEC modules when initialising.
I want to send my .NET Init message to the commandline after these AEC loading prompts
I tried waiting for Application.Idle(QuiescentState) without any luck.
Timing operations at startup is always tricky. You could try P/Invokignads_queueexpr (see example here - http://through-the-interface.typepad.com/through_the_interface/2006/08/calling_command.html). You could also user a timer to delay your message, although I'm not so keen on doing that.
But consider the 'arms race' that ensues when you and another add-in both want to send your init messages last - i.e. there's really no way AutoCAD can ensure any single addin gets to report itself last.
Board Manager
StephenPreston
Message 2 of 3 (160 Views)
Re: AutoCAD MAP end of loading AEC modules
12-06-2013 02:34 PM in reply to: SENL1362
Cheers,
Stephen Preston
Autodesk Developer Network
SENL1362
Message 3 of 3 (154 Views)
12-06-2013 02:45 PM in reply to: StephenPreston
Hello Stephen,
Thank you for this tip.
This and other reasons convince me to leafe the CommandLine for my output and use Panels to write the output to.
Anton
