Hi
I am try to insert Block into Layout in autocad map 3D 2014
but I get error if I try this in Autocad 2014 then it works well no error
can anyone help me please how I can fix this
Autodesk.AutoCAD.Runtime.Exception: eNotApplicable
at Autodesk.AutoCAD.EditorInput.Editor.UpdateTiledViewportsFromDatabase()
Namespace extracommands <CommandMethod("FRAME (A4)")> _ Public Shared Sub setjainnramman() ApplicationMenu.frameA4() End Sub Public Class ApplicationMenu Public Shared Sub frameA4() Dim doc As Document = _ Application.DocumentManager.MdiActiveDocument Dim db As Database = _ doc.Database Dim tr As Transaction = _ db.TransactionManager.StartTransaction() Dim ed As Editor = doc.Editor Using tr Try Dim layoutMgr1 As LayoutManager = _ LayoutManager.Current Dim layoutId As ObjectId = _ layoutMgr1.GetLayoutId("A4") If layoutId.IsNull = True Then tr.Abort() Return End If Dim layoutObj As Layout = _ tr.GetObject(layoutId, _ OpenMode.ForWrite, False) Dim layId As ObjectId = _ layoutObj.BlockTableRecordId Dim layoutBtr As BlockTableRecord = _ tr.GetObject(layId, _ OpenMode.ForWrite, True) Dim id As ObjectId = Nothing Dim bt As BlockTable = _ tr.GetObject(db.BlockTableId, _ OpenMode.ForRead, True) Dim blkName As String = "A4-frame" If bt.Has(blkName) Then id = bt.Item(blkName) Dim insPt As New Point3d(0.7566, 0.6746, 0) Dim bref As BlockReference = _ New BlockReference(insPt, id) layoutBtr.AppendEntity(bref) tr.AddNewlyCreatedDBObject(bref, True) tr.Commit() Else tr.Abort() End If Catch ex As System.Exception ed.WriteMessage(ex.ToString()) End Try End Using End Sub End Class End Namespace
Regards
sgear
try to lock the document before starting the transaction (and dispose it after "End Using" of the "tr").
To try the code I guess it's depending on the drawing you try to insert the block into (and if external the file "A4-frame" too), please upload this/them.
Have you installed the latest servicepack for Map3D 2014? (>>>click<<<).
- alfred -
