.NET
AutoCAD Line Object, Draw lines
1 REPLY 1
Lvcien
939 Views, 1 Reply
Hi Everyone,
I have a client who would like me to develop an application that will do the following:
Open AutoCAD
Load an empty drawing
Define a line in memory while specifying it's start and end points, then add it to the DWG file.
I also need to open existing drawings, select a block of data (ie: 4 lines that make a rectangle, etc) then scale the drawing down and place it on the drawing in a set location.
Once the data has been drawn to a DWG the file is saved.
Where (& how) can I create a line object in memory, draw it - and refernce it by it's name/ID etc.
ie:  Dim line as AutoCADLine   - where AutoCADLine is the type
I've read there's a few ways to work with autocad - I'm using the interops DLL's but it doesn't appear that it has the ability to do what I need.
I'd really appreciate it if someone could point me in the correct direction for some C# code that draws pre-defined objects onto the drawing surface.  Also, reading parts of a drawing from a DWG file is critical as well...
C
1 REPLY 1
Hallex
in reply to: Lvcien
See on-line docs for more please
>>HotTo<<
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
”Boost
