.NET
AutoCAD is loaded property
1 REPLY 1
bobbyg
392 Views, 1 Reply
Does anyone know if there's an isloaded() property for AutoCAD? I'm developing a plugin that checks for updates during the initialization process, and from 2012+ this causes a crash. I've put the update checking in a backgroundworker, and it fixes it, but this seems like a bandage instead of an actual fix. I would definitely like to see if anyone else has had this problem, and what their solution was. Thanks.
1 REPLY 1
chiefbraincloud
in reply to: bobbyg
You might try Autodesk.AutoCAD.ApplicationServices.Application.IsQuiescent
Don't know for sure if that will work, but it's worth a shot.
”Boost
