.NET
Active Member
0 Kudos
Post 1 of 2
AutoCAD is loaded property
139 Views, 1 Replies
05-21-2012 06:44 AM
Does anyone know if there's an isloaded() property for AutoCAD? I'm developing a plugin that checks for updates during the initialization process, and from 2012+ this causes a crash. I've put the update checking in a backgroundworker, and it fixes it, but this seems like a bandage instead of an actual fix. I would definitely like to see if anyone else has had this problem, and what their solution was. Thanks.
You might try Autodesk.AutoCAD.ApplicationServices.Application.IsQuiescent
Don't know for sure if that will work, but it's worth a shot.
54 Kudos
Post 2 of 2
Re: AutoCAD is loaded property
05-21-2012 09:24 AM in reply to: bobbyg
