There are many ways to get all objects from db
Here is what you can to use, expand functionality
to your suit:
[CommandMethod("gall")] public void GetAllFromDb() { Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor ed = doc.Editor; ObjectIdCollection ids = new ObjectIdCollection(); using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction()) { for (long i = 0; i < db.Handseed.Value; i++) { ObjectId id = ObjectId.Null; db.TryGetObjectId(new Handle(i), out id); if (id != ObjectId.Null && !id.IsErased) ids.Add(id); } foreach (ObjectId id in ids) { DBObject obj = tr.GetObject(id, OpenMode.ForRead, false) as DBObject; ed.WriteMessage("\nType of:\t{0}\t{1}\n", obj.GetRXClass().DxfName,id); } } }
~'J'~
This code is working fine , no problem on that, but what i'm looking for is, how i can get all the objects user does, because i need to export all objects (lines, circles...etc) and in the xml, I will export all properties of those objects (air, length...etc)
thanks a lot of help
In this case better yet to use datextraction methods,
search for this on google or on "through the interface" web page:
http://through-the-interface.typepad.com/
there is an example in there
~'J'~
Here is my old code I've grabbed from Kean Walmsley
See if this helps
#region "System" using System; using System.IO; using System.Collections.Generic; using System.Linq; using System.Text; using System.Runtime.InteropServices; using System.Diagnostics; using System.Data; using System.Timers; using System.Windows.Forms; #endregion #region "AutoCAD Imports" using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.DataExtraction; #endregion //--------------------------------------------------// //' based on Kean Walmsley's example from there: //' http://through-the-interface.typepad.com/through_the_interface/2008/04/extracting-data.html [CommandMethod("extdata")] public void ExtractData() { Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor; double starttime = 0; double endtime = 0; System.Windows.Forms.OpenFileDialog dialog = new System.Windows.Forms.OpenFileDialog(); dialog.CheckPathExists = true; dialog.CheckPathExists = true; dialog.DefaultExt = "dwg"; dialog.DereferenceLinks = true; dialog.Multiselect = false; dialog.Filter = "Drawing (*.dwg)|*.dwg|All files (*.*)|*.*"; dialog.Title = "Select drawing"; dialog.FilterIndex = 1; if (dialog.ShowDialog() != System.Windows.Forms.DialogResult.OK) { return; } string fname = dialog.FileName; System.Timers.Timer _timer = new System.Timers.Timer(); _timer.Interval = 1000; _timer.Start(); starttime = DateTime.Now.TimeOfDay.TotalMilliseconds; try { //------------------------------------------------------------------------------------------------------ // following datatable easy to write to the any data file (Excel, Access etc) System.Data.DataTable dataTable = extractLinesAndTexts(fname); _timer.Stop(); //------------------------------------------------------------------------------------------------------ endtime = DateTime.Now.TimeOfDay.TotalMilliseconds; //' write data to Lines.xml in the Debug folder dataTable.WriteXml("LinesAndTexts.xml"); ed.WriteMessage("\nElapsed time: {0:f2} milliseconds" + "\n" + "Found {1} objects\n" , endtime - starttime, dataTable.Rows.Count); } catch (System.Exception ex) { MessageBox.Show(ex.ToString() + "\n" + ex.StackTrace); } //' Display the file Process.Start("LinesAndTexts.xml", null); } public System.Data.DataTable extractLinesAndTexts(string fname) { System.Data.DataTable dataTable = new System.Data.DataTable(); System.Data.DataTable blkTable = new System.Data.DataTable(); Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument; Editor ed = doc.Editor; List<string> tags = new List<string>(); if (!System.IO.File.Exists(fname)) { ed.WriteMessage("\nDrawing file does not exist.\n"); return null; } IDxExtractionSettings es = new DxExtractionSettings(); IDxDrawingDataExtractor de = es.DrawingDataExtractor; de.Settings.ExtractFlags = ExtractFlags.None | ExtractFlags.ModelSpaceOnly; de.Settings.ExtractFlags = ExtractFlags.ExtractBlockOnly; //'Or ExtractFlags.ModelSpaceOnly IDxFileReference fr = new DxFileReference(Path.GetDirectoryName(fname), fname); de.Settings.DrawingList.AddFile(fr); // Scan the drawing for object types & their properties de.DiscoverTypesAndProperties(Path.GetDirectoryName(fname)); List<IDxTypeDescriptor> types = de.DiscoveredTypesAndProperties; // Select all the types and properties for extraction // by adding them one-by-one to these two lists List<string> selTypes = new List<string>(); List<string> selProps = new List<string>(); foreach (IDxTypeDescriptor type in types) { selTypes.Add(type.GlobalName); foreach (IDxPropertyDescriptor pr in type.Properties) { if (!selProps.Contains(pr.GlobalName)) { selProps.Add(pr.GlobalName); } } } de.Settings.SetSelectedTypesAndProperties(types, selTypes, selProps); // Now perform the extraction itself de.ExtractData(Path.GetDirectoryName(fname)); // Get the results of the extraction dataTable = de.ExtractedData; if (dataTable.Rows.Count > 0) { dataTable.TableName = "LinesAndTexts"; DataRow[] selrows = dataTable.Select("AcDxObjectTypeGlobalName Like '%Line' Or AcDxObjectTypeGlobalName Like '%Text' Or AcDxObjectTypeGlobalName Like '%MText'"); blkTable = dataTable.Clone(); foreach (DataRow dr in selrows) { blkTable.ImportRow(dr); } //' commented code lines is just for populating a form listBox control: //Dim columns As String() = New String() {"AcDxObjectTypeName"} //Dim dvw As DataView = blkTable.DefaultView //distinctTable = dvw.ToTable(False, columns) //Dim bnames As New List(Of String)() //For Each dr As System.Data.DataRow In distinctTable.Rows // Dim bname As String = dr(0).ToString() // If Not bnames.Contains(bname) Then // bnames.Add(bname) // End If //Next //Me.lst.DataSource = bnames'' <-- to fill ListBox only //lst.SelectedIndex = -1'' <-- set selected items to nothing } return blkTable; }
~'J'~
