.NET
DiogoSantos
Message 1 of 9 (323 Views)
AutoCAD dwg into image format
323 Views, 8 Replies
06-21-2012 04:17 AM
I'm trying to "transform" an autocad drawing into an image format file, but I only can get the image that is in the main window, never the whole drawing. Anybody can help me how to get the whole drawing and convert it to an image format file.
Thanks and kind regards,
Diogo
Distinguished Contributor
Artvegas
Message 2 of 9 (292 Views)
Re: AutoCAD dwg into image format
06-22-2012 10:51 PM in reply to: DiogoSantos
What image format are you interested in? Vector? Raster? How are you going about it? If you are talking about a raster image then maybe the ScreenShot plugin-of-the-month might have what you are looking for: http://through-the-interface.typepad.com/through_the_interface/2009/11/novembers-plugin-of-the-month...
Distinguished Mentor
gasty1001
Message 3 of 9 (280 Views)
06-23-2012 03:54 PM in reply to: DiogoSantos
You can plot the drawing to a raster file (jpg or png) using the publish to web (jpg/png) pc3.
Gaston Nunez
DiogoSantos
Message 4 of 9 (269 Views)
06-24-2012 09:29 AM in reply to: DiogoSantos
Yes that is really what i want, but I want to do it programmatically. I want to raster the whole drawing to an image like jpeg or a png image. Do you have any ideas how can I accomplish that?
Diogo
Artvegas
Message 5 of 9 (264 Views)
06-24-2012 10:07 AM in reply to: DiogoSantos
I can see two options:
1. Programatically zoom-extents your drawing and take a screenshot as per the ScreenShot plugin; or
2. Programatically plot the drawing to an image format as suggested by Gaston.
I would go for option 2 as you will have full control over the resolution of the raster image produced.
To get you started, the following lists a bunch of posts for programatically plotting in AutoCAD:
http://through-the-interface.typepad.com/through_the_interface/plotting/
Searching these forums and I'm sure you'll find something that suits.
Hope this helps.
DiogoSantos
Message 6 of 9 (254 Views)
06-24-2012 01:45 PM in reply to: DiogoSantos
First of all thanks for all the answers, I've been searching in that blog that you mentioned and it always creates a dwf file, what I want is a jpeg or a png file, I think maybe it has something to do with the configuration used like this:
psv.SetPlotConfigurationName(ps, "DWF6 ePlot.pc3", "ANSI_A_(8.50_x_11.00_Inches)");
Because when it calls the function to generate the output file:
pe.BeginDocument( pi, doc.Name, null, 1, true, "c:\\test-output");
This will create test-output.dwf file, maybe this has something to do with that option DWF6 ePlot.pc3
Is there any configuration for jpeg or png file?
Diogo
Artvegas
Message 7 of 9 (244 Views)
06-24-2012 08:44 PM in reply to: DiogoSantos
Yes DWF6 ePlot.pc3 will plot to *.dwf. To see what other plot configurations are available on your system check the plot dialog in AutoCAD. For *.jpg try using PublishToWeb JPG.pc3 and for *,png try using PublishToWeb PNG.pc3.
DiogoSantos
Message 8 of 9 (232 Views)
06-25-2012 03:01 AM in reply to: DiogoSantos
Yes that was it, once I used
acPlSetVdr.SetPlotConfigurationName(acPlSet, "DWG to PDF.pc3", "ANSI_A_(8.50_x_11.00_Inches)");
It creates a pdf file.
Thanks a lot,
Diogo
New Member
jmurua
Message 9 of 9 (225 Views)
06-25-2012 06:16 AM in reply to: DiogoSantos
   Public Shared Sub GenerarImagenExterna(ByVal archivoDWG As String, ByVal tamaino As Drawing.Size)
        Dim imagen As Drawing.Bitmap
        Dim acadDoc As Document
        Dim acadDocs As DocumentCollection
        acadDocs = Application.DocumentManager
        acadDoc = acadDocs.Open(archivoDWG, forReadOnly:=False)
        imagen = acadDoc.CapturePreviewImage(width:=CType(tamaino.Width, UInteger), height:=CType(tamaino.Height, UInteger))
        acadDoc.CloseAndDiscard()
        imagen.Save(IO.Path.ChangeExtension(archivoDWG, ".png"))
    End Sub
