.NET
AutoCAD Developer Documentation Survey
2 REPLIES 2
Virupaksha_aithal
834 Views, 2 Replies
It is my pleasure to announce the launch of the AutoCAD Developer Documentation Survey. This survey is to collect information about your impression of the developer documentation and to determine our priorities. I hope you’ll be willing to give 5-10 minutes of your time to take the survey – the results will be used to guide the efforts of our developer documentation team.
Here is the link to the survey -
https://www.surveymonkey.com/s/H72RWJC
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
2 REPLIES 2
Hi Virupaksha!
Is there a date of completion for the AutoCAD Developer Documentation Survey?
Facebook | Twitter | LinkedIn
Expert Elite Member
Deadline is March 31st 2013.
Cheers,
Stephen Preston
”Boost
