.NET
Autocad commands not executing in time.
13 REPLIES 13
Message 1 of 14
617 Views, 13 Replies
I have a c# application. If i net load it in autocad it will show a modal dialog. If i press a button in that form, it should hide and it should open a dwg file in autocad. and after opening i wrote the code to show another modal dialog.
My problem is if i click the button it will directly show the second form without opening the dwg file. It will open only if i close the second form.
Autocad commands is not executing in time. Can anyone suggest what may be the problem?
// commands.cs file
// This is how i am opening the dwg file
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open(filename, false);
// Here i am opening the second form.
objCreate = new CreateTemplate(std, filename, "Edit");
Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(objCreate);
thanks in advance
Jithin Edited by: jithin.dcs on Nov 30, 2009 8:58 AM
13 REPLIES 13
Message 2 of 14
Sorry, this isn't really enough code to diagnose the problem.
In cases like this, the calling context is very relevant, all the
way back to the command the user issues to start the dialog.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6296332@discussion.autodesk.com...
modal dialog.
the problem?
// commands.cs file
false);
thanks in advance
Jithin
Message 3 of 14
hi,
thanks for your reply.. here is the code
// Button click
private void btnEditTemplate_Click(object sender, EventArgs e)
// Hiding the first modal dialog
this.Hide();
// Function call to open the dwg file and show the second modal dialog (this function is in commands.cs file)
Commands.ShowTemplateEdit(filename, tvTemplates.SelectedNode.Parent.Text);
// Function in commands.cs
// Function to show the drawing and edit template window (Only for edit)
static public void ShowTemplateEdit(string filename,string std)
// Declaring the second form object
CreateTemplate objCreate;
Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
filenameforOpen = filename;
} Edited by: jithin.dcs on Nov 30, 2009 10:31 AM
Message 4 of 14
The only way I think you can do this, is to have the code that displays the
dialog (e.g., calls Application.ShowModalDialog()) open the file, after the
call to the latter returns.
wrote in message news:6296370@discussion.autodesk.com...
hi,
// Button click
this.Hide();
Editor ed =
false);
Message 5 of 14
hi,
i have tried that also. I called show modal dialog and after showing the form i returned some value and then i tried to open file. The same thing happened here also. It showed the form only and not opened the file. If i close the form, then at that moment the file opens.. Actually i need to show some xdata information to the form from the opened file. So if this works also that will not help me..
any other suggestions...?
Message 6 of 14
You don't show the CommandMethod that starts everything, and what
CommandFlags it uses.
Does it use CommandFlags.Session ?
If so, there should be no problem opening a file after the call to
ShowModalDialog() returns.
wrote in message news:6297749@discussion.autodesk.com...
hi,
Message 7 of 14
i dont want to open file after modal dialog shows. I want to open file first and then display the modal dialog. so that i can read xrecords from drawing and show it in modal dialog.
Message 8 of 14
You still haven't answered the question about your command and whether it
runs in the application context or the document context.
wrote in message news:6297866@discussion.autodesk.com...
Message 9 of 14
i am calling a function in the commands.cs file from the modal dialog's button click. This function (in commands.cs file) will open a drawing and then it should show the second modal dialog. So in the document context only i am doing both the things..
Message 10 of 14
hi
i m also facing the same problem
i prompt the user to select a starting point
after selecting a point i will show a dialogbox which contains two buttons continue and End
if user clicks on conitnue then i prompt the user to select the another point
now i will pass these two points to a lisp command (by loading the lisp file and send these values)
then a drawing is generated
after drawing is generated i show the dialogbox whether to continue or end
if user selects continue then the same process is repeated
please help me
Message 11 of 14
I can't really help further without seeing the declaration of the method
with the CommandMethod attribute.
wrote in message news:6298484@discussion.autodesk.com...
Message 12 of 14
hi,
i solved the problem. as u said earlier, i used commandflags.session and inside the method i wrote code for both file open and show modal. then it worked properly.
thank you very much for your support
Jithin Shyam
Message 13 of 14
hi
i too facing with the same problem
but with a small difference , u r opening a dwg file
but i m executing a lispfunction
if u dont mind please can u tell me how you solved your problem
with a sample code
thanks in advance
vijay kumar
Message 14 of 14
hi vijay,
I wrote code for opening a drawing as well as calling modal dialog show in the same command method and it has parameter command flags as session.
for example
[CommandMethod("OpenDwg",CommandFlags.Session)]
static public void OpenDwg()
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open(filenameforOpen, false);
objcreate = new CreateTemplate(selectedStd, filenameforOpen, "Edit");
Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(objcreate);
thanks
Jithin Shyam S
”Boost
