.NET
37 Kudos
Post 11 of 17
Re: AutoCAD Commands from vb.net 2010
03-26-2012 10:46 AM in reply to: vbNinja
Add these lines to the top of the class
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Colors
and add the reference to
acdbmgr.dll
acmgd.dll
and set copy local to false.
(defun botsbuildbots() (botsbuildbots))
Valued Mentor
20 Kudos
Post 12 of 17
03-26-2012 10:47 AM in reply to: vbNinja
What  namespaces have you imported? Is this a standalone EXE application?
37 Kudos
Post 13 of 17
03-26-2012 10:50 AM in reply to: Mike.Wohletz
the above code won't work for a stand alone exe.
0 Kudos
Post 14 of 17
03-26-2012 11:13 AM in reply to: Mike.Wohletz
Hi
I have the following imports:
Imports System
Imports System.Runtime.InteropServices
Imports Autodesk.AutoCAD.Interop
And yes this is a standalone EXE Application
0 Kudos
Post 15 of 17
03-26-2012 11:14 AM in reply to: Mike.Wohletz
Hi
Imports System
And yes this is a standalone EXE application
Valued Mentor
20 Kudos
Post 16 of 17
03-27-2012 06:04 AM in reply to: vbNinja
Try something like this to set the layer colors:
    Private Sub WorkingWithAutoCAD()
        ' we can set the color of one layer or current by:
        acSetLayerColor(AcColor.acYellow)
        'or
        'set them all to green
        For Each oLayer As AcadLayer In ThisApplication.ActiveDocument.Layers
            acSetLayerColor(AcColor.acGreen, oLayer)
        Next
        ' or set the OB layer to red and see if it happened calling by name
        Dim Rval As Boolean = acSetLayerColorByName(AcColor.acRed, "OB")
    End Sub
    Private Function acSetLayerColor(ByVal oColor As AcColor, Optional ByVal oLayer As AcadLayer = Nothing) As Boolean
        Try
            If oLayer Is Nothing Then 'we will look at the current layer
                oLayer = ThisApplication.ActiveDocument.ActiveLayer
            End If
            oLayer.color = oColor
            Return True
        Catch ex As Exception
            Return False
        End Try
    End Function
    Private Function acSetLayerColorByName(ByVal oColor As AcColor, ByVal oLayerName As String) As Boolean
        Try
            Dim oLayer As AcadLayer = ThisApplication.ActiveDocument.Layers.Item(oLayerName)
            Return True
            Return False
        End Try
    End Function
0 Kudos
Post 17 of 17
03-27-2012 10:01 AM in reply to: Mike.Wohletz
Hi
Your suggestions worked after I added a reference to acdbmgd.dll and acdmgd.dll and imported these namespaces:
Thank you all for your help.
Best regards
