.NET
AutoCAD command prompt text disapear
4 REPLIES 4
andre_adc-dao
844 Views, 4 Replies
Hi everybody,
I've developed a custom insert block command. The first one insert a block from a dialog box like the INSERT command. Everything work fine. Now I created a palette with a list of block. When I click one, my custom insertion command is issue. The block is insert correctly but after insert, the text "Command:" is not displaying at the command line (I see only the text issue by my command with WriteMessage) but I can type another command with no problem.
If I send an escape string, the text is back again but I see *cancel* at command line, so it is not very elegant.
Anybody have an idea?
André
4 REPLIES 4
depending on the AutoCAD release, for newer ones:
        Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt
if that does not exist, then for older releases
        <DllImport("acad.exe", CallingConvention:=CallingConvention.Cdecl, CharSet:=CharSet.Unicode, EntryPoint:="?acedPostCommand@@YAHPB_W@Z")> _
        Public Function acedPostCommand32(ByVal CommandStr As String) As Integer
        End Function
        <DllImport("acad.exe", CallingConvention:=CallingConvention.Cdecl, CharSet:=CharSet.Unicode, EntryPoint:="?acedPostCommand@@YAHPEB_W@Z")> _
        Public Function acedPostCommand64(ByVal CommandStr As String) As Integer
        End Function
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
You're a king!!!!
Best regards,
André
norman.yuan
in reply to: andre_adc-dao
Well, doing the P/Invoke gets what you want, you can do it even easier with the managed API equivalent directly:
Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
Norman Yuan
Drive CAD With Code
Hi Norman,
have you seen my first option in my post?
- alfred -
Alfred NESWADBA
”Boost
