.NET
.NET
*pkirill
Message 1 of 5 (215 Views)
AutoCAD Bogging Down During Long Batch Process
215 Views, 4 Replies
05-16-2006 08:36 AM
I've got a vb.net app that processes a list of drawings for updating,
plotting or saving. If I load it with about 20 drawings, it is pretty
quick - about 10-20 seconds to open and process a drawing. If I load it
with say, 75 drawings, once it get to 25-30, it starts to lose steam. Around
the 40th drawing it is taking 3-4 minutes to process a drawing.
Watching the command line I see that most of the code sent to AutoCAD
completes, then there is a long pause before finishing with a plot or save
command. During this pause, there is no HD activity, no CPU or memory spike
that I can see. It just sits there. So I'm wondering if there is some kind
of AutoCAD "cache" I should be flushing during my loops to keep the lag time
down.
If anyone has any ideas, I'd sure appreciate hearing them!
Thanks!
Oh: AutoCAD 2005, Windows XP Pro, 2GB RAM, P43.0 (DC), 80GB 10kRPM hard
drive...
*Tim Riley
Message 2 of 5 (215 Views)
Re: AutoCAD Bogging Down During Long Batch Process
05-16-2006 11:08 AM in reply to: *pkirill
Lets see some code. Can't really dubug otherwise.
Tim
http://tjriley.infogami.com/pyacaddotnet
"pkirill" wrote in message
news:5176042@discussion.autodesk.com...
down.
Thanks!
drive...
*Tim Riley
Message 3 of 5 (215 Views)
05-16-2006 11:12 AM in reply to: *pkirill
Also you might want to look into this thread for some insight.
http://www.theswamp.org/index.php?topic=6292.0
Tim
down.
Thanks!
drive...
*pkirill
Message 4 of 5 (215 Views)
05-16-2006 11:29 AM in reply to: *pkirill
That's a great thread. I'll have to take a close look, though as at first
pass it's over my head. Below I've pasted the portion of the code that
handles the looping. It's probably a mess, and I apologize for that... I'd
be thrilled to send you the entire project, but woulnd't want to impose.
As always, any help is appreciated!
Private Sub Plot_Only()
ResetProgress()
frmDLPlot.frmProgressForm.Show()
ReDim strDwgs(UBound(frmDLP.ardwgs2) - 1)
ReDim Preserve frmDLP.FinFileName(UBound(frmDLP.ardwgs2) - 1)
ReDim Preserve strDwgNumber(frmDLP.lstDrawings.Items.Count - 1)
Dim i As Integer = 0
Dim itemChecked As Object
'dwg.SetVariable("SDI", 1)
For i = 0 To UBound(frmDLP.ardwgs2) - 1
System.Windows.Forms.Application.DoEvents() 'check for outside event - ie.
CANCEL button click
If blnProgressCancel = True Then 'If the Cancel button is clicked then goto
EOF2
GoTo EOF2
Else
If InStrLast(frmDLP.FinFileName(i), "_") > 1 _
And loadini.blnDullesSpecial Then
loadini.blnDullesSpecialAutoCreate = True
Else : loadini.blnDullesSpecialAutoCreate = False
' If Len(strFileName) > 0 Then
' otherwise process the drawing fro plotting
'PlotScale = loadini.strPlotScaleList(i) 'get the plot scale from the
loadini subr
'strFileName = loadini.strDrawingNameList(i) 'get the file name from the
loadini subr
PlotScale = frmDLP.FinPlotScale(i)
strFileName = frmDLP.FinFileName(i)
frmDLPlot.frmProgressForm.lblStatusDwgName.Text = strFileName
frmDLPlot.frmProgressForm.lblStatusProcess.Text = "Opening"
frmDLPlot.frmProgressForm.Update()
strDwgs(i) = loadini.strFilePath & strFileName & ".dwg" 'add the path and
".dwg"
If InStrLast(frmDLP.FinFileName(i), "_") = 1 _
strDwgs(i) = loadini.strCompositeFilePath & strFileName & ".dwg"
' If frmDLP.lstDrawings.GetItemChecked(i) = True Then 'See if the item is
checked and if so
If System.IO.File.Exists(strDwgs(i)) Then 'verify the drawing exists
If loadini.blnDullesSpecialAutoCreate = True Then
'If the file name has an underscore not in the first position
'"_" AND it is a dulles autocreate file then
Try
System.IO.File.Delete(strDwgs(i)) 'try to delete the file
Catch 'if it's open,
blnShowErrMessage = True 'add a line to the error message to be displayed at
the end
strFileErrorMsg = strFileErrorMsg & vbCr & frmDLP.FinFileName(i) & "
*OPENFILE*"
GoTo PLOTNEXT 'then move on to he next file
End Try 'end check for open dulles file
dwg = acad.Documents.Add(strDwgs(i)) 'if the file was deleted, create a new
file with the same name
acad.WindowState = AcWindowState.acMax 'maximize autocad
acad.ActiveDocument.WindowState = AcWindowState.acMax 'maximize the document
Else
AutoCADcommandRunning:
Try
dwg = acad.Documents.Open(strDwgs(i), False)
Catch ex As Exception
' Check for error message...
If ex.Message = "Call was rejected by callee." Then
acad.Visible() = True
MsgBox("**There is an active command in AutoCAD**" & vbCr & vbCr & _
"Click into AutoCAD and cancel the current AutoCAD command." & vbCr & vbCr &
_
"THEN return here press OK to continue the Batch Process",
MsgBoxStyle.Exclamation, "AutoCAD Busy")
GoTo AutoCADcommandRunning
End Try
'if it is not a dulles SHEET drawing, just open it
End If 'END IF loadini.blnDullesSpecial
ElseIf System.IO.File.Exists(strDwgs(i)) = False And
loadini.blnDullesSpecial Then 'otherwise if the file does not exist and is a
dulles sheet file
'MsgBox(strDwgs(i))
dwg = acad.Documents.Add(strDwgs(i)) 'just create it
loadini.blnDullesSpecial = False Then 'and finally, if the drawing does not
exist and it is not a dulles drawing, skip it,
blnShowErrMessage = True 'adding a line to the error message
strFileErrorMsg = strFileErrorMsg & vbCr & frmDLP.FinFileName(i) & " *NOT
FOUND*"
GoTo PLOTNEXT 'and goto the next drawing
End If 'END If System.IO.File.Exists(strDwgs(i))
'NEW DULLES DRAWING PROCESSING
If loadini.blnDullesSpecialAutoCreate = True And loadini.blnDullesSpecial
Then
frmDLPlot.frmProgressForm.lblStatusProcess.Text = "Creating Dulles Sheet"
dwg.SendCommand("(load ""NewDullesDwgCheck"")" & vbCr & "(NewDullesDwgCheck
" & """" & _
loadini.strCommission & """" & " " & """" & frmDLP.FinFileName(i) & """" & "
" & _
"""" & loadini.strDwgDirectory & """" & ")" & vbCr)
End If 'END InStrLast(loadini.strDrawingNameList(i), "_") > 1 And
'RUN MISC SCRIPTS
If frmDLP.chkDwup.Checked = True And loadini.blnDullesSpecialAutoCreate =
False Then 'Send DwuP command
dwg.SendCommand("dwup" & vbCr)
frmDLPlot.frmProgressForm.lblStatusProcess.Text = "Updating Border"
If frmDLP.chkSpanner.Checked = True Then 'Send Spanner Update command
dwg.SendCommand("sheetall" & vbCr)
frmDLPlot.frmProgressForm.lblStatusProcess.Text = "Updating Spanner"
If frmDLP.chkPurge.Checked = True Then 'Send PUA command
dwg.SendCommand("pua" & vbCr)
frmDLPlot.frmProgressForm.lblStatusProcess.Text = "Purging"
If frmDLP.chkChgco.Checked = True Then 'Send Chgco command
dwg.SendCommand("chgco" & vbCr)
frmDLPlot.frmProgressForm.lblStatusProcess.Text = "Color BYLAYER"
If frmDLP.chkZoomExt.Checked = True Then 'Send Zoom Extents
dwg.SendCommand("ze" & vbCr)
frmDLPlot.frmProgressForm.lblStatusProcess.Text = "Zooming"
If frmDLP.chkAudit.Checked = True Then 'Send Audit Command
dwg.SendCommand("audit" & vbCr & "yes" & vbCr)
frmDLPlot.frmProgressForm.lblStatusProcess.Text = "Auditing"
If Len(frmDLP.txtRevNum.Text) > 0 Then
If frmDLP.chkShowAllTri.Checked = True Then
strShowAllTri = "Y"
Else : strShowAllTri = "N"
frmDLPlot.frmProgressForm.lblStatusProcess.Text = "Handling Revisions"
dwg.SendCommand("(revdisplay " & """" & frmDLP.txtRevNum.Text & """" & " " &
"""" & strShowAllTri & """)" & vbCr)
If frmDLP.chkShowAllRev.Checked = True Then
dwg.SendCommand("(ALLREV_T)" & vbCr)
If frmDLP.chkShowNoRev.Checked = True Then
dwg.SendCommand("(ALLREV_F)" & vbCr)
' If Not frmDLP.cboStamps.Text = "No Stamp" Then
strPEStamp = frmDLP.FinPEStamp(i)
PlotWithStamp()
dwg.Regen(AcRegenType.acActiveViewport)
' End If
Dim USERI5 As String = "0"
If frmDLP.chkXrefLog.Checked = True Then
frmDLPlot.frmProgressForm.lblStatusProcess.Text = "Logging Xrefs"
dwg.Application.LoadDVB("G:\CAD Standards\HCYU
Standards\__HCYU\Lisp\XrefLog.dvb")
dwg.Application.RunMacro("G:\CAD Standards\HCYU
Standards\__HCYU\LISP\XrefLog.dvb!ThisDrawing.MakeXrefLog")
If Not frmDLPlot.strProcess = "OPEN" Then
If frmDLPlot.strProcess = "PLOT" Or frmDLPlot.strProcess = "BOTH" Then
'frmProgress.Update()
DwgPlot(dwg, i) 'Plot this drawing
If frmDLPlot.strProcess = "PLOT" Then
frmDLPlot.frmProgressForm.lblStatusProcess.Text = "Closing"
dwg.Close(False)
If frmDLPlot.strProcess = "SAVE" Or frmDLPlot.strProcess = "BOTH" Then
Dwgsave(dwg, i)
dwg.Close(False)
Dim intProgressCount As Integer =
frmDLPlot.frmProgressForm.prgProgress.Value
If Not intProgressCount >= frmDLPlot.frmProgressForm.prgProgress.Maximum
Then
intProgressCount += 1 ' add 1 to progress count
frmDLPlot.frmProgressForm.prgProgress.Value = intProgressCount
frmDLPlot.frmProgressForm.lblDwgProcessed.Text = intProgressCount.ToString
PLOTNEXT:
Next 'i
EOF2:
blnProgressCancel = False
If frmDLPlot.strSaveDest = "ARCHIVE" Then
frmDLPlot.frmProgressForm.lblStatusProcess.Text = "Archiving"
Dim objWriter As New System.IO.StreamWriter(frmArch.strArchiveList, True)
frmArch.strArchLog = loadini.strCommission & " , " & frmArch.strArchDesc & "
, " & loadini.strDiscipline & " , " & modBatchProcess.strDate & " , " &
Environ$("username")
objWriter.WriteLine(frmArch.strArchLog)
objWriter.Close()
blnAcState = False
frmDLPlot.frmProgressForm.Hide()
'dwg.SetVariable("SDI", 0)
If blnAcadExist = False And frmDLP.radOpenOnly.Checked = False Then
If frmDLP.blnLeaveOpen = False Then
acad.Quit()
For i = 0 To UBound(frmDLP.arFinDwgList) - 1
frmDLP.arFinDwgList(i) = ""
Next
For i = 0 To UBound(frmDLP.FinPlotScale) - 1
frmDLP.FinPlotScale(i) = ""
Next
For i = 0 To UBound(frmDLP.FinFileNumber) - 1
frmDLP.FinFileNumber(i) = ""
Next
For i = 0 To UBound(frmDLP.FinFileName) - 1
frmDLP.FinFileName(i) = ""
Next
End Sub
*Tim Riley
Message 5 of 5 (215 Views)
05-16-2006 12:02 PM in reply to: *pkirill
If you want to feel free to send the entire project to riltim@gmail.com and
I'll take a look at it. I'm hardly a VB.NET pro but maybe I can help. You
also might want to try creating an account and posting over there in the
.NET section of theswamp.org. I know there are several who should be able to
help you there.
Tim
news:5176436@discussion.autodesk.com...
ResetProgress()
CANCEL button click
EOF2
GoTo EOF2
Else
loadini subr
loadini subr
".dwg"
checked and if so
Try
the end
*OPENFILE*"
Else
Try
_
End Try
dulles sheet file
'MsgBox(strDwgs(i))
FOUND*"
Then
" & """" & _
" & _
'RUN MISC SCRIPTS
strShowAllTri = "Y"
PlotWithStamp()
' End If
dwg.Close(False)
Dwgsave(dwg, i)
dwg.Close(False)
Then
PLOTNEXT:
Next 'i
EOF2:
objWriter.Close()
blnAcState = False
acad.Quit()
Next
Next
Next
Next
End Sub
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
