.NET
autoCad application setup
6 REPLIES 6
548 Views, 6 Replies
Hi
How can I create a setup for autocad  map application. I just want to load the tool (dot net Arx C#) application from user installation directory.
Murali
6 REPLIES 6
kdub_nz
Write the code.
Compile.
Either NETLOAD
or configure through the registry to demand load.
Regards
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
class keyThumper<T> : Lazy<T>;      another  Swamper
Alexander.Rivilis
http://through-the-interface.typepad.com/through_the_interface/2010/09/building-an-installer-part-1....
http://through-the-interface.typepad.com/through_the_interface/2010/09/building-an-installer-part-2....
http://through-the-interface.typepad.com/through_the_interface/2010/09/building-an-installer-part-3....
Facebook | Twitter | LinkedIn
Expert Elite Member
kdub_nz
in reply to: Alexander.Rivilis
Alexander, I didn't think the AutoLoader would load from user defined folders ... I'll need to re-read those links.
Regards
Alexander.Rivilis
in reply to: kdub_nz
Regards
Kerry! I do not understand where these topics AutoLoader? These topic's are about creating setup (MSI). 😉
Expert Elite Member
kdub_nz
I may have misinterpreted the OP's question.
Regards
kdub_nz
Would be nice if the OP came back to comment 🙂
”Boost
